查看: 1706|回复: 6
cj后台进不去
发表于 2007-11-24 22:46:37 | 显示全部楼层 |阅读模式
RT
发表于 2007-11-24 23:09:30 | 显示全部楼层
似的
发表于 2007-11-24 23:56:40 | 显示全部楼层
是的,一样的
500 Servlet Exception
java.lang.NullPointerException: null buffer || null address
        at java.net.PlainDatagramSocketImpl.send(Native Method)
        at java.net.DatagramSocket.send(DatagramSocket.java:612)
        at org.apache.log4j.helpers.SyslogWriter.write(SyslogWriter.java:69)
        at org.apache.log4j.helpers.QuietWriter.write(QuietWriter.java:39)
        at org.apache.log4j.helpers.SyslogQuietWriter.write(SyslogQuietWriter.java:45)
        at org.apache.log4j.net.SyslogAppender.append(SyslogAppender.java:245)
        at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:221)
        at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders(AppenderAttachableImpl.java:57)
        at org.apache.log4j.Category.callAppenders(Category.java:187)
        at org.apache.log4j.Category.forcedLog(Category.java:372)
        at org.apache.log4j.Category.log(Category.java:864)
        at org.apache.commons.logging.impl.Log4JLogger.info(Log4JLogger.java:133)
        at org.apache.struts.util.PropertyMessageResources.<init>(PropertyMessageResources.java:127)
        at org.apache.struts.util.PropertyMessageResourcesFactory.createResources(PropertyMessageResourcesFactory.java:90)
        at org.apache.struts.util.MessageResources.getMessageResources(MessageResources.java:577)
        at org.apache.struts.action.ActionServlet.initInternal(ActionServlet.java:1329)
        at org.apache.struts.action.ActionServlet.init(ActionServlet.java:464)
        at javax.servlet.GenericServlet.init(GenericServlet.java:82)
        at com.caucho.server.http.Application.createServlet(Application.java:3114)
        at com.caucho.server.http.Application.loadServlet(Application.java:3065)
        at com.caucho.server.http.QServletConfig.loadServlet(QServletConfig.java:435)
        at com.caucho.server.http.Application.getFilterChainServlet(Application.java:2809)
        at com.caucho.server.http.Application.buildFilterChain(Application.java:2765)
        at com.caucho.server.http.Invocation.service(Invocation.java:313)
        at com.caucho.server.http.HttpRequest.handleRequest(HttpRequest.java:246)
        at com.caucho.server.http.HttpRequest.handleConnection(HttpRequest.java:163)
        at com.caucho.server.TcpConnection.run(TcpConnection.java:139)
        at java.lang.Thread.run(Thread.java:595)
Resin 2.1.13 (built Tue Mar 30 10:27:50 PST 2004)
发表于 2007-11-25 02:43:39 | 显示全部楼层
那今天做的单子能不能跟踪到哦,晕死~!
发表于 2007-11-25 15:30:51 | 显示全部楼层
还不行啊,怎么回事
发表于 2007-11-26 15:02:51 | 显示全部楼层
单子可以跟踪到,幸好幸好~!
发表于 2007-11-27 13:25:58 | 显示全部楼层
不是一个服务器
GMT+8, 2025-4-18 11:29
