查看: 1446|回复: 2
也是RocketTheme的商业主题Dimensions Light
发表于 2007-11-27 11:02:40 | 显示全部楼层 |阅读模式
游戏主题估计没多少人用,这个主题估计好点,改下很好看。
主题名称: Light
商业版权: RocketTheme商业主题
适用程序: Joomla 1.0.x & Joomla 1.5 & Mambo 4.5.3
A variation of the popular RocketTheme Dimensions template, theDimensions Light mod gives you the stylish design and features ofDimensions with a light coloured look and feel. Use this mod for yourDimenions based projects, or use it as a starting point for your owntemplate mod to create anything you want.
This mod features the same easy background image and accent color changing abilities as the regular Dimensions template.
Dimensions Light Mod
A few key features of this template are as follows:
    * Joomla 1.0+ compatible
    * Easy color and background modification
    * Dynamic time based style changes
    * Incredible new tabbed module system
    * 15 module positions
    * All module positions are fully collapsible
    * XHTML 1.0 Transitional
    * Mozilla/Firefox 1.0+/IE 6/IE 7/Safari/Camino/Opera Friendly
Current Version: 1.0.2
下载地址
参与人数 2 +20 收起 理由
lojofo + 10
妖刀 + 10
发表于 2007-11-27 21:24:28 | 显示全部楼层
: 旅游站吧
发表于 2007-12-1 17:40:02 | 显示全部楼层
一般。
GMT+8, 2025-4-20 10:15
