查看: 1681|回复: 4
求助,收到inflating traffic (forcing clicks) 警告信
发表于 2008-5-29 18:09:38 | 显示全部楼层 |阅读模式
收到cj警告信
In accordance with Commission Junction’s Publisher Service Agreement you agreed to follow, you are being warned for violating the Publisher Service Agreement by inflating traffic (forcing clicks) to one or more of your affiliated advertisers.  As you should know, clicks and Transactions are only considered valid when generated by an affirmative-action by the End-User/Visitor. You may not generate clicks or transactions for the advertisers you are affiliated with unless you have documented authorization from the advertiser to do so. As a result, your account is under payout and status review.
You must remove any and all mechanisms that inflate traffic or force clicks within 48 hours of receipt of this warning notice.  Failure to do so may result in the termination of your Commission Junction Publisher account and the charge-back (reversal) of transactions, and any attempt to rejoin the Commission Junction Network shall be null and void.
If you have questions regarding this notice, please reply to this email using the provided reply-to address and leave the subject line intact.
Publisher Support and Compliance
Commission Junction, a ValueClick company
已去掉网站上广告代码,什么时候可再放上广告代码?
不能再放代码了吗?
发表于 2008-6-2 01:49:11 | 显示全部楼层
我的直接来信说,号关了
发表于 2008-6-2 23:01:02 | 显示全部楼层
最近CJ K得很凶
发表于 2008-6-7 15:49:12 | 显示全部楼层
说实话的呢,能正规就尽量正规
发表于 2008-8-26 16:37:38 | 显示全部楼层
还是正规做吧
GMT+8, 2025-4-19 20:57
