查看: 2932|回复: 9
AdBie Search Engine 3.5
发表于 2008-11-6 10:03:49 | 显示全部楼层 |阅读模式
Ads Search Engine 3.5
www.AdBie.com
[ 本帖最后由 无限可能 于 2008-11-6 10:05 编辑 ]
adbiese3php5.zip
158.63 KB, 下载次数: 19
售价: 10 e币  [记录]
发表于 2008-11-6 17:27:37 | 显示全部楼层
能不能简单介绍下
发表于 2008-12-4 21:26:13 | 显示全部楼层
我买了怎么不能下 啊
OK,原来是没钱了
[ Last edited by mianfei8 at 2008-12-4 21:29 ]
发表于 2008-12-14 14:59:25 | 显示全部楼层
楼主测试过可用????!!!!!!!
发表于 2008-12-14 19:32:07 | 显示全部楼层
今天测试了下,有问题啊
在ADMIN中配置好了 点SAVE 显示
Warning: fopen(../configs/config.conf) [function.fopen]: failed to open stream: Permission denied in /home/abc/public_html/libs/admin.lib.php on line 223
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 225
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 227
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 231
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 233
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 235
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 237
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 239
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 241
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 245
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 247
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 249
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 251
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 255
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 257
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 259
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 261
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 263
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 265
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 267
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 269
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 271
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 273
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 275
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 277
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 279
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 293
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 309
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 319
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 329
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 345
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 347
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 349
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 357
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 359
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 361
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 363
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 365
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 369
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 371
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 373
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 375
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 377
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 379
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 381
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 383
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 385
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 387
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 389
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 391
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 393
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 395
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 397
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 399
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 401
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 403
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 441
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 443
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 445
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 447
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 449
Warning: fputs(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 451
Warning: fclose(): supplied argument is not a valid stream resource in /home/abc/public_html/libs/admin.lib.php on line 453
发表于 2008-12-31 13:32:53 | 显示全部楼层
我的分值够吗?
发表于 2010-7-15 12:43:49 | 显示全部楼层
还是这儿好啊
发表于 2010-7-15 12:45:23 | 显示全部楼层
没弄懂这是什么东西
发表于 2010-8-15 17:58:00 | 显示全部楼层
什么东东这么贵啊
发表于 2010-8-20 11:10:16 | 显示全部楼层
什么时候能发帖啊?我的2004年的老号丢了,现在成新兵了。
adbrite.com还是不错的GG,YAHOO之外的选择
GMT+8, 2025-4-19 13:53
