查看: 12898|回复: 147
英文原创文章流氓创作方法
发表于 2008-11-20 01:18:11 | 显示全部楼层 |阅读模式
想做好英文站最基本的要求就是原创,但是毕竟咱母语是中文,lol,咱们很多人当初都没把英语当回事,现在用上了吧! 但是,没事老外的那么多产品咱们国人都山寨出来了,何况做伪原创文章了
Hi guys,
Seeing that everyone is sharing ideas here,
i said that is the time to expose a little trick that i use for some time now,
and that can be used by you also.
If you need good content, and you do not
want to spend a dime on it, and you also try to avoid the google duplication
penalties, then you should use this method.
Go to any warez website, browse
the ebook and tutorials section and there you will find plenty of ebooks written
on very different subject: health niche, loan, dating, banks, materials,
information, almost anything you want.
Then take the chapters from the book
and turn them into articles, blogposts, forum posts, whatever you need. You can
add a note at the end of the article, written by the original creator.
This
content is seen by google as fresh, because in general those ebooks have never
been indexed by google.
It bypass any copyscape filter, and it is very good
for mfa or informational sites. Most of these ebooks are really well written by
professionals.
So from now on, you should have plenty of materials for your
website.
Cheers.
要点是在warez找ebook找其中的章节拼凑,自己加个介绍或者总结,K.O.!
转自点石 作者:干部们
我个人认为英语-德语-英语  英语-法语-英语 这样翻译的顺序作伪原创也是很not bad的方法!
再补充一个方法:如果是采集站的话 可以用火车头高级版本 我记得一个火车头的版主说过好像火车采用的是一个大学做出来的翻译引擎
听说效果还不错 大家可以看看 我体验过一次 感觉是比gg强些(中文采集-翻译英文-发布)
参与人数 2 +15 收起 理由
过客 + 5 我很赞同
netxboy + 10 我很赞同
发表于 2008-11-20 01:26:09 | 显示全部楼层
LZ说的第二个方法我以前在静水论坛发过,可能很多人没看到。
其实还有一种方法实现伪原创,专门针对SE的,但是用户体验不太好
第二种方法有个老外朋友写了一个小程序,很方便
需要装上.NET Framework 3.5
  1. http://download.microsoft.com/download/2/0/e/20e90413-712f-438c-988e-fdaa79a8ac3d/dotnetfx35.exe
[ Last edited by netxboy on 2008-11-20 02:03 ]
UCM.zip
584 KB, 下载次数: 138
参与人数 1 +10 收起 理由
dxszzcylm + 10 我很赞同
 楼主| 发表于 2008-11-20 01:42:40 | 显示全部楼层
做sale的话 当然要认真的写的哈 可能我没说清 这些是针对seo方面的 伪原创 来了流量 怎么来lead 大家应该有各自的招数了
发表于 2008-11-20 01:54:07 | 显示全部楼层
来看看
发表于 2008-11-20 02:14:22 | 显示全部楼层
Unique content maker帖个图
 楼主| 发表于 2008-11-20 02:28:15 | 显示全部楼层
今天在论坛上也看到一个类似的软件 回来我找找 下载下来一起放过来
netxboy 这软件not bad 方便些 lol 我一般都用gg翻译的
[ Last edited by sorcerer on 2008-11-20 02:29 ]
发表于 2008-11-20 07:10:12 | 显示全部楼层
发表于 2008-11-20 07:15:30 | 显示全部楼层
很not bad的说.
发表于 2008-11-20 07:53:04 | 显示全部楼层
看看  什么好方法
发表于 2008-11-20 08:16:37 | 显示全部楼层
我一般就翻译一下就完事了!
发表于 2008-11-20 10:01:30 | 显示全部楼层
我看一下这篇文章
发表于 2008-11-20 11:13:52 | 显示全部楼层
不知道这个效果到底如何啊
发表于 2008-11-20 11:24:35 | 显示全部楼层
就是伪的咱们也不懂呀
发表于 2008-11-20 11:34:54 | 显示全部楼层
看看先。。。。。。。。。。
发表于 2008-11-20 11:37:32 | 显示全部楼层
看看什么方法 多学习 现在是
发表于 2008-11-20 14:23:37 | 显示全部楼层
好像这种流量都是用来做google adsense的?
或者纯粹只是为了做个英文的有流量的,有搜录的站点?
第二种方法有一些用..
[ Last edited by 过客 on 2008-11-20 14:29 ]
发表于 2008-11-20 14:46:59 | 显示全部楼层
LOOKLOOK............
发表于 2008-11-20 14:56:51 | 显示全部楼层
还是GG来的方便些
发表于 2008-11-20 15:18:58 | 显示全部楼层
kan                                           kan
发表于 2008-11-20 15:23:24 | 显示全部楼层
Thank you!
GMT+8, 2025-4-20 04:38
