查看: 3067|回复: 10
Cilp-Share Pro 4.0.9 Nulled With 4 套模板 + 14国语言(含中文)
发表于 2009-2-20 17:16:42 | 显示全部楼层 |阅读模式
视频上传,分享,观看的网站类型.
CilpShare Overview
Dream to build your own highly profitable YouTube clone?
With ClipShare, now you’re limited only by your imagination, not by the software! Unleash the power of video sharing to boost your websites’ traffic & revenues!
With a huge variety of features and options, at an extremely affordable price, ClipShare is the ultimate solution for starting your video sharing and uploading community website just like the big boys: Youtube, Metacafe, DailyMotion, LiveVideo, Vimeo, MySpace Videos or Google Video.
Changes:
4.0.7
- fixed subscriber packages info in siteadmin
- fixed clipshare version bug introduced by 4.0.6
- fixed subscriber notice in include/function.php
- fixed convert.php flv re-conversion bug (only worked for flv, not for FLV)
- fixed categories/ID/TITLE_UTF8 not found error
- fixed friends photo display in userfriends
- fixed friends photo display in users/USERNAME/friends
- fixed type in siteadmin static pages edit
- fixed typo and notices in upload_success
- fixed mailing return true/false
- added more languages
- added tags fix for 3.0.1 to 4.x (see upgrade/upgrade3.0.1_FINAL_to_4.0.tags_fix.php)
Changed files:
include/function_admin.php
convert.php
.htaccess
friends.php
templates/friends.tpl
templates/ufriends.tpl
templates/siteadmin/index_static.tpl
upload_success.php
include/language.php
4.0.8
- fixed rss feeds not found bug when installed in a subfolder
- fixed security problem in msg.php (a loggedin user was able to view any message (Thanks Artanis))
- fixed check system in siteadmin (missing logs, sessions, thumbs and uploader directories)
- fixed embed bug in view_video.tpl
- fixed poll add system (if the date was the same, date would be considered in the past)
- fixed notice in login
- fixed notice in login_data
- fixed paypal user account upgrade payment (Thanks Perspicacious)
- fixed friend private videos error
- fixed video links bug when SEO urls are not activated
- fixed view_video friends bug
- fixed scriptaculous errors
- fixed successfuly type (should be successfully)
- fixed uploadsuccess invalid video url and embed code
- language translations missing in templates
Changed files:
.htaccess
msg.php
siteadmin/modules/index/check.php
templates/siteadmin/index_check.tpl
templates/view_video.tpl
siteadmin/modules/index/polladd.php
login.php
renew_account.php
uvideos.php
templates/head_bottom/videolinks.tpl
view_video.php
js/foldeing/scriptaculous.js
language/en_US/*
upload_success.php
templates/upload_success.tpl
templates/index.tpl
templates/right.tpl
templates/mygroup.tpl
templates/ugroups.tpl
templates/search_group.tpl
templates/groups.tpl
4.0.9
- fixed a security bug in templates/search.tpl (thanks phantom-a)
- typos in ufriends.tpl (thanks phantom-a)
- fixed avatar update problem (caching)
- fixed tags problem (see: http://forums.clip-share.com/48- ... ious-user-accident/)
Changed files:
my_profile.php
upload.php
Installation:
1. Edit /upload/cgi-bin/ubr_upload.pl in a text editor, and change the path to (where you will insall the script)/tmp/uploader/
2. Edit /upload/include/config.php in a text editor, and change the variables marked with "CHANGE HERE"
3. Edit /upload/include/dbconfig.php and enter your database info
4. Optional: Edit /upload/include/language.php to remove / add language files
5. Upload the contents (only the contents, not the folder itself) of the /upload folder on your server, in BINARY mode
6. Set write permissions (chmod 777) to the following folders:
/flvideo
/video
/thumb
/chimg
/photo
/tmp
/tmp/logs
/tmp/sessions
/tmp/thumbs
/tmp/uploader
/cache/templates_c
7. Set execute permissions (chmod 755) to /cgi-bin and /cgi-bin/ubr_upload.pl
8. Create database and database user. Import the database dump from /sql/clipshare.sql with phpmyadmin
9. Access your ClipShare Admin Panel at http://www.yourdomain.com/siteadmin/
Default admin user / password: admin / admin
- Change the admin user / password !!
- Change the site name, email, meta keywords, description, etc
- Optional: change different settings
- Create channels
- Add your advertising
- You can check if all requirements and configurations are met on the "System Check" page
演示:http://video.bobll.com/
参与人数 2 +35 收起 理由
回忆月光 + 32
txf861 + 3
发表于 2009-2-20 17:48:12 | 显示全部楼层
貌似手头有了
 楼主| 发表于 2009-2-20 21:47:41 | 显示全部楼层
河马,我知道你很多资源的,发个出来和大家分享吧.
发表于 2009-2-20 21:52:51 | 显示全部楼层
现在鬼子的主机,查null查的厉害。。。哎。
发表于 2009-2-20 22:25:43 | 显示全部楼层
做这个太好资源了,没有独立服务器的还是别想了!
发表于 2009-2-20 23:32:02 | 显示全部楼层
看了楼上的留言,断了念头了。
发表于 2011-1-8 17:16:32 | 显示全部楼层
好东西 占位 待查
发表于 2011-1-9 08:36:02 | 显示全部楼层
怎么样才能下载呢
发表于 2011-1-9 16:54:18 | 显示全部楼层
好东西 占位 待查
发表于 2011-1-25 02:43:56 | 显示全部楼层
太贵,下不起
发表于 2011-2-12 09:29:41 | 显示全部楼层
  看看
GMT+8, 2025-4-19 07:04
