查看: 1663|回复: 1
godaddy空间因版权被关闭,请高人指点怎么恢复?
发表于 2009-2-28 21:20:05 | 显示全部楼层 |阅读模式
发来的EMAIL中提示:
PLEASE NOTE:
We are not a court, nor are we dictating who, if anyone, has the rights
to the work(s) in question.  We are merely acting in accordance with the
DMCA requirements for Hosting Providers.  If there is a dispute as to
the ownership of the content, that should be addressed in a court of
law.  As a result, situations, circumstances, and details do not usually
need to be submitted to GoDaddy.com or it's affiliates.
A list of the specific portions of your site in question are listed
below.  For detailed questions, you will need to contact the Complainant
at the address listed below.
Description of the Infringement(s)
SEE ATTACHED NOTIFICATION
Complainant:
In order to resolve this situation and re-activate your site, you have 2
options.
Option 1. Remove the content in question.
In order to reactivate the site in question we will need you to provide
the following information in a single email response:
   A. An electronic signature. (This can be a scanned copy of your
physical signature, or as simple as typing your full name.)
   B. Identification of the material in question.
   C. A statement, under penalty of perjury, that the material has
either been removed or will promptly be removed.
Option 2. Submit a complete Counter Notification on the works in
question in accordance with our Copyright Dispute policy. (See Above)
You will need to reply, via email and include all of the following
elements.
   A.   An electronic signature of the Infringer. (This can be a scanned
copy of your physical signature, or as simple as typing your full name.)
   B. Identification of the material that has been removed or to which
access has been disabled and the location at which the material appeared
before it was removed or access to it was disabled.
   C. A statement under penalty of perjury that the Infringer has a good
faith belief that the material was removed or disabled as a result of
mistake or misidentification of the material to be removed or disabled.
   D. The Infringer's name, address, and telephone number, and a
statement that the Infringer consents to the jurisdiction of the Federal
District Court for the judicial district of Arizona, or if the
Infringer's address is outside of the United States, for any judicial
district in which Go Daddy may be found, and that the Infringer will
accept service of process from the Complaining Party or an agent of such
Party.
PLEASE NOTE:
The term "The Infringer" is used for identification purposes only.  This
is not an indication of any alleged guilt or innocence.
If you have any further questions, please let us know.
Regards,
Copyright Claims Department
GoDaddy.com
[email protected]
发表于 2009-2-28 22:12:16 | 显示全部楼层
我的处理方法是告诉GD,只是把空间借给别人用,不是自己用,马上帮我开通空间,我去把侵权的文章或者网站删除,并向被侵权方道歉.
这个回信的时间一定要一收到就马上回复
GMT+8, 2025-4-16 03:50
