查看: 1314|回复: 2
你的网站添加X-UA-Compatible meta标签了吗?
发表于 2009-3-7 14:10:44 | 显示全部楼层 |阅读模式
细心的朋友会发现下面的html代码中多了一个<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />标签!
     <meta http-equiv="Content-Type" content="text/html; charset=gb2312" />
     <meta http-equiv="Content-Language" content="gb2312" />
     <meta name="robots" content="all" />
     <meta name="googlebot" content="all" />
     <meta name="description" content="提供最新的asp源码,php源码,.net源码,flash源码,网站源码,网页源码,模板,软件下载" />
     <meta name="keywords" content="asp源码,php源码,.net源码,flash源码,网站源码,网页源码,模板,软件" />
     <title>源码下载网 - 提供最新免费网站源码下载</title>
     <META name="copyright" content="www.downhtml.com" />
        那这个标签是什么意思呢?让我来看下msdn上的说明:
        In IE8 Beta 1, that option is the “IE=7” X-UA-Compatible tag, which instructs IE8 to display content in IE7 Standards mode. However, the scenario this doesn’t address is when IE=7 is applied as an HTTP header to a site that contains Quirks mode pages. The IE=7 HTTP header will force all pages – both Quirks and Standards – to display in IE7 Standards mode. Developers using this header while updating their sites would then have to add the “IE=5” <META> tag to each page they want to keep in Quirks mode. This logic is fine for many websites. However, if a site has lots of Quirks mode pages, or for the case where pages with frames host a mix of Strict and Quirks mode content – as brought to light by IE8 Beta 1 user feedback – the compatibility opt-out adds a bit more work than we intended.
     X-UA-Compatible是针对ie8新加的一个设置,对于ie8之外的浏览器是不识别的,这个区别与content="IE=7"在无论页面是否包含<!DOCTYPE>指令,都像是使用了 Windows Internet Explorer 7的标准模式。而content="IE=EmulateIE7"模式遵循<!DOCTYPE>指令。对于多数网站来说,它是首选的兼容性模式。
      目前IE8尚在测试版中,所以为了避免制作出的页面在IE8下面出现错误,建议直接将IE8使用IE7进行渲染。也就是直接在页面的header的meta标签中加入如下代码:
<meta http-equiv="X-UA-Compatible" content="IE=7" />
这样我们才能使得页面在IE8里面表现正常! http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />标签!
<META name="copyright" content="Downhtml.com" />
  In IE8 Beta 1, that option is the “IE=7” X-UA-Compatible tag, which instructs IE8 to display content in IE7 Standards mode. However, the scenario this doesn’t address is when IE=7 is applied as an HTTP header to a site that contains Quirks mode pages. The IE=7 HTTP header will force all pages – both Quirks and Standards – to display in IE7 Standards mode. Developers using this header while updating their sites would then have to add the “IE=5” tag to each page they want to keep in Quirks mode. This logic is fine for many websites. However, if a site has lots of Quirks mode pages, or for the case where pages with frames host a mix of Strict and Quirks mode content – as brought to light by IE8 Beta 1 user feedback – the compatibility opt-out adds a bit more work than we intended.
  X-UA-Compatible是针对ie8新加的一个设置,对于ie8之外的浏览器是不识别的,这个区别与content="IE=7"在无论页面是否包含指令,都像是使用了 Windows Internet Explorer 7的标准模式。而content="IE=EmulateIE7"模式遵循指令。对于多数网站来说,它是首选的兼容性模式。
参与人数 2 +4 收起 理由
dxszzcylm + 2
nod32 + 2
发表于 2009-3-7 14:38:53 | 显示全部楼层
受教了
学习了
谢谢LZ分享
发表于 2009-3-8 00:11:46 | 显示全部楼层
一篇值得推荐的技术文章!
GMT+8, 2025-4-20 22:57
