查看: 1550|回复: 10
再发一个站长不能错过的“内容为王”的模板
发表于 2009-8-10 10:35:18 | 显示全部楼层 |阅读模式
这个模板也是joomla平台上的最经典的“内容为王”模板,出自著名的joomlart,希望做英文站的朋友能用得上。
JA Pollux - 1st JATC template for Nov 06 is released. JoomlArt is proud to bring to our club members another highly accessible Joomla design. With a simple and grey color, JA Pollux is recommended for a portal site with large content. As with all other JA templates, the accessibility matters of the templates are of high attention. The essence of accessibility is to put the content of a web page first and the design second, therefore the "Content First" CSS technique is introduced in this Joomla! template; if you view source codes of the JA Pollux demo site, you will see that the main body texts are loaded first instead of left column like other templates. This not only means that the content is easier to view with all types of browsers but also helps with search engine rankings. Moreover, five built-in menu options are revamped and all menu items now have their own title tag: New! Especially, the Horizontal JA Dropline menu Updated! has been totally rewritten so that users can navigate more comfortably since its first appearance in JA Kruger. All of these improvements are simply part of our effort to enhance web accessibility for your Joomla! sites.
Advertising with Joomla is now even more interesting when the JA CoolAds module is provided with JA Pollux. Your text ads, banner, or even a rotation of newsflash modules can be delivered to your reader in a smart animation with full configuration via Admin (show/hide "close - do not show again" buttons, animation speed, first load delay...).
An overview of JA Pollux key features:
* 4 layout options: 3 columns, 2 columns-full left, 2 columns-full right, collapse all
* All user modules are fully collapsible
* JA CoolAds module New!
* Three screen types: narrow, wide, auto-adjustmentNew!
* 2 color options, modern design with plenty of whitespace
* Tableless design and 100% CSS based
* Joomla 1.0.x + Joomla 1.5 compatible
* 5 Menu options: Standard Joomla menu, Horizontal JA split, Horizontal JA Dropline Updated!, JA Transmenu and JA Suckerfish.
* XHTML 1.0 Transitional Check it ?
* CSS Validates Check it ?
* Valid 508 Accessibility
* Delivered with source.PSD and FONT files, detailed user guide which can be found in JA Pollux download folder.
* Well-commented template_css.css and index.php file for flexible customization
JA_Pollux_FreeShareAll[1].Com.rar
6.63 MB, 下载次数: 1
售价: 15 e币  [记录]  [购买]
发表于 2009-8-10 16:46:06 | 显示全部楼层
模版也有内容为王的?模版直接带内容了?
 楼主| 发表于 2009-8-10 23:44:23 | 显示全部楼层
不是模板带内容,是这个模板专门针对内容做了优化,能最大化发挥内容的功能,可以仔细看看介绍啊
发表于 2009-8-11 12:43:59 | 显示全部楼层
回复下,好好看看,认真学习
发表于 2009-8-11 15:56:57 | 显示全部楼层
楼主的东西还行啊,我也好好看看
发表于 2009-8-11 22:58:38 | 显示全部楼层
不错,支持下.能给一个DEMO就好了.
发表于 2009-8-14 02:52:29 | 显示全部楼层
上一个DEMO:
http://www.joomlart.com/templates_demo.php?template=ja_pollux
感觉这样的没有joomla的风格,需要的话不如直接用WP。
发表于 2009-9-24 09:03:23 | 显示全部楼层
发一个站长不能错过的“内容为王”的模板
发表于 2009-10-4 19:38:17 | 显示全部楼层
模版也有内容为王的?模版直接带内容了?
发表于 2009-11-8 18:50:41 | 显示全部楼层
好歹带张图嘛
发表于 2009-11-23 21:25:05 | 显示全部楼层
怎么没图
GMT+8, 2025-4-20 17:40
