查看: 1375|回复: 2
U.S. recession seen ending in third quarter
发表于 2009-8-11 16:08:18 | 显示全部楼层 |阅读模式
By Lucia Mutikani Lucia Mutikani – Mon Aug 10, 1:20 pm ET
WASHINGTON (Reuters) – The worst U.S. recession since the Great Depression will probably end in the third quarter, but uncertainty exists over the speed and duration of the economic recovery, according to the most recent survey of private economists.
The Blue Chip Economic Indicators survey of private economists released on Monday showed about 90 percent of the respondents surveyed believe the economic downturn will be declared to have ended this quarter.
This upbeat assessment followed recent government data showing gross domestic product (GDP) contracted at a shallow 1.0 percent rate in the second quarter after sinking 6.4 percent in the January-March quarter.
Recent data, including housing and key labor market indicators, have suggested a bottoming in the recession and the economy close to turning the corner. The economy slipped into recession in December 2007.
The Blue Chip survey's findings are broadly in line with a Reuters poll published last month, which predicted growth in the third quarter, though a brisk pace of expansion was not expected until late 2010.
"Debate now centers on the speed, strength and durability of the recovery," the survey said.
It showed nearly two-thirds of respondents believed the economy was set for a U-shaped recovery, marked by below-trend growth in gross domestic product before stronger growth took hold in the second half of 2010.
About 17 percent of the respondents anticipated a V-shaped rebound, where growth pulled back to its trend rate on a sustained basis, while the same percentage fretted that a W-shaped recovery could follow, the survey showed.
"In their view, GDP growth will pop higher for a quarter or two only to falter again before a lasting recovery takes hold," the survey said.
HIGHER GDP GROWTH
Growth in the second half was expected to garner support from a reduction in the pace of business inventory liquidation, marginal improvements in consumer spending and residential investment. The survey predicted that non-residential investment, however, would remain a drag on GDP.
Despite the improved economic picture, unemployment was expected to remain a problem, with the jobless rate predicted to peak at just over 10 percent late this year or early 2010, the survey showed. It was seen falling only slowly thereafter.
Government data on Friday showed the unemployment rate nudged down to 9.4 percent in July from 9.5 percent in June, but mostly because many people dropped out of the labor force.
"About 70 percent of the panelists believe the jobless rate will not dip below 7.0 percent on a sustained basis until the second half of 2012 or later," the survey said.
However, job losses could fade late this year or early 2010 and payrolls start to expand as companies rebuild inventories, which should lengthen the workweek, according to the survey.
The weak labor market, together with excess capacity in many business sectors were seen dampening inflation pressures.
"Consumer price inflation, excluding food and energy costs, will increase by slightly less in 2010 than in 2009," the survey said.
(Reporting by Lucia Mutikani; Editing by Theodore d'Afflisio)
 楼主| 发表于 2009-8-11 16:08:48 | 显示全部楼层
东西是YAHOO的
我觉得怎么没有什么感觉。
号码还是不发钱。或者不给批
发表于 2009-10-5 14:27:38 | 显示全部楼层
这样的文章看着很没有意思。
GMT+8, 2025-4-19 10:13
