查看: 5552|回复: 57
花5到7分钟,伪原创出质量很好的文章。送三款软件。
发表于 2009-10-11 18:16:15 | 显示全部楼层 |阅读模式
I'm gonna give you all a method for getting unique content on your blogs that works and is 100% complete from start to finish. The concept of what I'm about to tell you is nothing new to BHW but the tools I use may not be familiar to some of you.
The method I use for getting content involves article grabbing, translating the articles several times, and then checking the dupe content level before I post it.
The reason I wrote this thread is because I see a lot of people on here wanting to use some translator bots and stuff that BHW members have made and then yanked or else the software has glitches and other problems and the method I've found works flawlessly so I thought I would share.
Now before we get started, this method is not for autobloggers cause you wil spend a few minutes getting your articles ready to post, but if you've got a few minutes to spin a few articles you'll have lots of content for your blogs.
Okay here we go, these 3 tools are the tools you will need for the job:
The Everprofits Toolbar - I take no credit for having found this tool, Ken3401 is responsible for giving me this tool for getting my articles in the first place. Now all you haters are gonna say that the Everprofits toolbar no longer grabs articles using the content generator tool that comes with it, but while that was true for awhile, they've updated their toolbar and if you have the latest version of it, it grabs articles again without any problems. Much thanks to Ken3401 for a great tool recommendation.
You can G00gle 'Everprofits Toolbar' to get the download
The next tool you will need is the Lingoes translator, it's free and uses all the major translation services around the Internet including G00gle translator. It's a small app that you download and set up on your pc and it really translates articles super fast but you do have to feed the articles in for each pass of the translation, so about 2 minutes per article.
You can G00gle 'Lingoes translator' to get the download
The last tool you will need is a dupe content checker, and you can use whichever checker you want, but DupeFree Pro is free and works perfectly well for the job.
You can G00gle 'DupeFree Pro' to get the download
* Now before anyone goes asking, I'm not affiliated with these softwares in any way, they are just the tools I use for spinning articles cause they work very well, and I haven't posted enough to be able to give you the links so you have to go grab them yourselves.
Okay so here's what you do to spin articles:
First: Download all programs and install them
Second: Let's find an article to spin so open up Internet Explorer and click on the Content Generator in the Everprofits toolbar. Once you've opened the content generator, type in your keyword and press the search button and wait for a list of articles to show up. Once you've got your list, click on an article you want to use and it will populate in the rewriter screens below it. I don't use the rewriter feature of this toolbar because it turns the articles to dogfood so instead I highlight and copy out the content of the article (CTRL+C) and then I open up Lingoes.
Third: Once you've got Lingoes open maximize it so you can see all of the contents of the articles you will spin, then click on the Text Translation button right in the center of the window. Paste your article into the text box, use the G00gle translator and translate the article. I go English to Spanish, then I copy out the Spanish and if you right click in the text box it will highlight all the original text for you and you can just paste in the Spanish with one click. I do this again for Spanish to French, then French to German, then German back to English.
*The whole process up to this point from finding and grabbing the article to translating it is 2 minutes, for a noob who haven't used the software before it's like 4 minutes..so it's pretty quick.
Now the last step is to copy out your article that is now in English and check it through DupeFree Pro, so open up DupreFree Pro and paste your spun article in one window, go back to your Everprofits toolbar content generator window and copy the original article again and paste it in the other DupeFree Pro window and click the big fat compare button.
I've had results in the 23% to 35% range, never higher and the spun article is human readable and quite good with one or two small grammar tweaks that need to be applied to the article. The whole process takes about 3 to 4 minutes and could be faster if you know what you're doing.
So there you go, that's the method, it works, but you do have to spend a few minutes grabbing and translating, but then you've got articles that when checked in Copyscape don't even come up.
大概意思是说:先用Everprofits Toolbar在网上抓取你想要的文章,
再用灵格斯进行翻译,最后用DupeFree Pro处理一下。
这样得到的文章能够通过 Copyscape
这三款软件都能在网上免费得到这儿分享给大家。
Ever Profits Toolbar
http://toolbar.everprofits.com/toolbar/?
Lingoes
http://rapidshare.com/files/212540361/lingoes_portable_2.5.3.zip
DupeFree
http://rapidshare.com/files/212543064/DupeFreeProInstallation.msi
参与人数 1 +1 收起 理由
tjqipei + 1
发表于 2009-10-11 18:22:24 | 显示全部楼层
LZ先介绍下什么软件啊
发表于 2009-10-11 19:02:28 | 显示全部楼层
没真相~~怎么买啊~~~~~~
发表于 2009-10-11 19:44:31 | 显示全部楼层
应该有个介绍先哈 这样大家知道有用过没哦
 楼主| 发表于 2009-10-11 19:57:28 | 显示全部楼层
反正才2广告币,又不贵,懒得说。
发表于 2009-10-11 20:09:34 | 显示全部楼层
真还不错!
发表于 2009-10-11 20:09:56 | 显示全部楼层
广告币?哦,我的天哪
发表于 2009-10-11 22:21:19 | 显示全部楼层
你真是太棒了,谢谢了。
发表于 2009-10-11 23:00:58 | 显示全部楼层
现在是个帖就要钱了,论坛应该成立个工商局了
 楼主| 发表于 2009-10-11 23:31:28 | 显示全部楼层
发表于 2009-10-12 00:09:12 | 显示全部楼层
我晕,全英文啊
看来要花点时间看了
发表于 2009-10-12 12:38:31 | 显示全部楼层
原来是这样,感谢楼主了
发表于 2009-10-12 20:30:45 | 显示全部楼层
最后的中文句子亮了 回头下一个
发表于 2009-10-14 22:44:07 | 显示全部楼层
不是很了解
发表于 2009-10-15 04:35:30 | 显示全部楼层
得下载Toolbar,最烦这类的插件了
发表于 2009-10-15 09:32:26 | 显示全部楼层
是的,最怕安装工具栏
发表于 2009-10-16 00:58:41 | 显示全部楼层
这样该出来的文章效果如何?
发表于 2009-10-16 10:35:21 | 显示全部楼层
这种能出很好的效果吗?毕竟翻译机出来的东西...只能是获取流量
发表于 2009-10-19 14:49:54 | 显示全部楼层
原创的写不出来,只能用点伪的了
发表于 2009-10-25 10:36:22 | 显示全部楼层
翻译。。看的想。。
GMT+8, 2025-4-19 09:03
