查看: 1879|回复: 9
How to Transfer Domain to Godaddy
发表于 2010-3-3 11:56:49 | 显示全部楼层 |阅读模式
How totransfer a domain from other registrar to the world No.1 domain controland registration company – godaddy confused many people. This articleis an ultimate tutorial for doing this. We take Ixwebhosting forexample.
1st, Ixwebhosting side1, login your IX account then click Domain Products on the top left sidebar
2, Click “Manage” button below your domain product
3, Change Lock Settings
If your domain was on Locked stat, you must unlock it first.
Unlock it:
4, request the Authorization code for domain tranfer:
Click on the”Send Auth Code”, and then the authorization code will send to your email address.
5, Check your email, you’ll find a letter that named “Authorization code of your domain registration” from IXwebhosting.
Second step is on Godaddy side1, Login your godaddy account
2, Find the domain tranfer Options under the “Domain” drop-down menu
3, click in and enter with the domain name your want to transfer
4, then click “go” and “check out” button
5, in this step godaddy will recommend your some domain which with different extensions. Just click “No, thanks” to skip it.
6, set your domain DNS
7, the next few steps are the same as new godaddy domain registration, until review the shopping cart
8, pay for your offer for $6.99 plus a 18 cent fee,then godaddy will send you an email (to the address in your domainwhois record) with the Transaction ID and Security Code (veryimportant).
9, Log in to your godaddy account and click “Domain Manager” In the My Products section.
10, Select Pending Transfers from the Domains menu. You’ll see this:
11, Click the Authorization button and select Begin Transfer Authorization.
12, In the Transaction ID and Security Code fields, enter the codes which godaddy sent to you, then click Next.
13, Authorized for domain transfering, enter the code which ixwebhosting have sent to you.
Final step, click on the “Finish” button.
In the next 5 work days, you will receive an email from godaddy, and that’s means your domain transfer succeed.
参与人数 1 +7 收起 理由
几何黑店 + 7
发表于 2010-3-3 12:47:33 | 显示全部楼层
不错,收藏了,有用得上,嘿嘿
发表于 2010-3-3 14:27:42 | 显示全部楼层
英文版域名转移方法,谢谢分享!!!
发表于 2010-3-3 15:13:30 | 显示全部楼层
这个不错很实用,谢谢分享
发表于 2010-3-3 17:52:08 | 显示全部楼层
精品文章,收藏了。很实用
发表于 2010-3-3 19:16:59 | 显示全部楼层
很详细啊 谢谢分享
发表于 2010-3-4 11:36:31 | 显示全部楼层
thank you !
发表于 2010-3-4 18:14:57 | 显示全部楼层
这个不错很实用,谢谢分享
发表于 2010-3-18 19:07:54 | 显示全部楼层
确实非常实用,收藏了!!
发表于 2010-5-18 20:49:48 | 显示全部楼层
收藏了,,到时可以用到!~
GMT+8, 2025-4-14 12:34
