查看: 20537|回复: 141
【原创】全自动论坛文章群发Blogs Automater 1.5.3 + Keygen+建议
发表于 2010-3-27 14:23:06 | 显示全部楼层 |阅读模式
支持的BLOG
  1. Choose Your Blog Type:
  2. Blogs Organizer
  3. Blogger (free blog host)
  4. Wordpress.com (free blog host)
  5. Wordpress Blog
  6. Wordpress MultiUser Blog
  7. Adult Blog Hosts:
  8. Thumblogger (free blog host)
  9. SensualWriter (free blog host)
  10. Xlogz (free blog host)
  11. Custom Blog using:
  12. Blogger API 1.0
  13. Blogger API 2.0
  14. Metaweblog API
TIPS:1.你可以在templates页添加广告代码,然后群群建免费的BLOG群发文章。呵呵,添加好FEED和BLOG后完全自动的,需要支持cronjob的空间
2.想要full text的rss feed你可以使用yahoo 的pipes 非常好用。
3.用这个给你自己的wordpress发文章,找个好点的模板
4.免费BLOG推广自己的网站有利于SEO和PR
5.AD wordpress交流群 9933593
全自动-,-自己用了好久不玩了放出来啦。
安装
上传 安装 运行 ba.php 获得key
sales page
  1. hxxp://ba.cheapestwebsoftware.com
下载地址
  1. hxxp://www.mediafire.com/download.php?mxjnt5lljnc
  1. hxxp://qiufeng.org/Blogs_Automater_1.5.3+WithKeygen.zip
介绍
  1. Let's show You how to EFFORTLESSLY Turn ON the Auto Pilot on All Your
  2. Blogs and Turn them to 100% Automated Revenue EXPLODER Cash  Machines!
  3. In details what Blogs Automater does Automatically  for You:
  4. Operate Your Blogs  Totally Automatic!
  5. Yep, thats the SHOCKING  truth! Finally a product of new dimensions is introduced with which you can  automatically operate your blogs! It is the ultimate mass blogging software. It  can't be better than that!
  6.   Operate ALL Your Blogs!
  7. Just one install of  Blogs Automater is needed to operate all your blogs. No matter if you  have one or thousands of blogs, you can manage them just with one script install  and from one admin place. The location of your blogs does NOT matter - they can  be on same domain, same server, other domain, other server! What more could you  want?
  8. Automatically pull  content from RSS & ATOM feeds
  9. The software is  able automatically to extract new content from RSS & ATOM feeds. You don't  need to do anything else than just importing the feeds urls and let the script  do the rest!
  10. Supports All major blog platforms!
  11. The software is compatible  with a big variety of blog platforms and software. No matter if you use  Wordpress content management software or you have your blogs hosted at services  such as Blogger.com, Wordpress.com and others you can put them on auto pilot!  You can use it and with any other kind of blog software or service as long as it  supports remote XML-RPC administration!
  12. Smart Content Categorization &  Maintenance
  13. You are able to keep and maintain your feeds and content  organized by 2 different criterias - Sponsor and Category. This way you easily  can keep your content from different producers and from different  niches/categories separated.
  14.   Content Database
  15. All posts pulled from feeds  are stored in a database before publishing to your blogs. You are able to easily  browse your posts database, easily preview them and edit them if necessary!  Don't loose a post, let your posts database grow by itself with the time!
  16. Content Rewrite Engine
  17. Allows you to define set of keywords you  wish to be replaced with another set of keywords. It can even pick replacement  words by random! This helps improving your keyword density and improves  your Search Engines ranking.
  18.   Content Relink Engine
  19. Allows you to convert  defined set of keywords to hyperlinks automatically. This helps for interlinking  your own sites and pages and improves your Search Engines ranking and overall  traffic.
  20. Content Manipulation Engine
  21. You are able to assign the script  automatically make keywords bold, italic or underlined. This helps to bring more  attention to certain parts of your blog posts for the reader's eye.
  22. Links Rewrite  Engine
  23. The software is able automatically change the link targets and  their "rel" tag attribute to whatever values you want!
  24. Custom Content Inserts
  25. The software enables you to automatically insert  custom headers and footers to the posts published at your blogs. You are able to  make them more attractive and more money maker!
  26. Campaigns  Driven
  27. Blogs Automater is campaign based, allowing you multiple  and different rules for your rewrites, relinks, and etc... Basically for each  different blog you can define different settings you may need to meet that exact  blog personal style.
  28. Multi Category Support
  29. The software is able to publish  the posts to one or multiple categories at your blog (if your blog software  supports it).
  30. Keyword Based Publishing
  31. You can define a set of  keywords that a post should match to be published to a blog. With a smart search  engine, Blogs Automater can publish only highly keyword targetted posts  to your blogs.
  32. Unlimited Licensing
  33. The software is licensed to "single  domain install" only, meaning with one copy of it you have no restrictions on  the number of feeds to pull from, the number of posts to publish or the number  of blogs to publish to. Those are all unlimited! With ONE quick easy  install you are ready to automate ALL of your blogs on ALL of your  domains. No need to install it over and over again!
  34. Friendly and Helpful  Interface.
  35. Blogs Automater is designed pretty carefully to make  your work with it like a child's game. Everything is properly arranged and the  most important features are always just infront of your eyes. Most part of the  work you will regularly do is automated and you need mostly to use the mouse and  not the keyboard.
  36. Endless  Possibilities and Features
  37. Blogs Automater is a very complete blog  automation solution and it shows, it is used on a large number of websites  around the world. It is always under development and improvement, to provide you  unique features and possibilities. For your convenience we have listed an  overview of the most important features. By no means this list is indented to be  complete, but mentioning all the features of Blogs Automater would simply  take too much space
 楼主| 发表于 2010-3-27 14:29:02 | 显示全部楼层
配合
http://www.qiufeng.org/rss2/rss. ... urner.com/538dotcom 这样的 去除htmltags 只保留imgs和文字 无敌啦
 楼主| 发表于 2010-3-27 14:33:40 | 显示全部楼层
后台
发表于 2010-3-27 15:06:30 | 显示全部楼层
效果如何 谢谢分享了
发表于 2010-3-27 15:12:27 | 显示全部楼层
不错,看一下
发表于 2010-3-27 15:53:04 | 显示全部楼层
看起来是不错的工具,谢谢分享
发表于 2010-3-27 16:00:29 | 显示全部楼层
感谢分享,最重要是效果
发表于 2010-3-27 16:05:16 | 显示全部楼层
感谢分享,最重要是效果
发表于 2010-3-27 16:33:18 | 显示全部楼层
谢谢分享
发表于 2010-3-27 17:28:25 | 显示全部楼层
回复看下,感谢楼主!!
发表于 2010-3-27 17:28:38 | 显示全部楼层
看起来很不错,谢谢了
发表于 2010-3-27 17:41:18 | 显示全部楼层
自己玩的效果怎么样?
发表于 2010-3-27 18:12:48 | 显示全部楼层
怎么是自己不用了才放出来,难道是已经属于淘汰的产品,疑惑中,当然有些工具就算老了但是仍然有价值的。
发表于 2010-3-27 18:21:51 | 显示全部楼层
还是很有价值的
发表于 2010-3-27 18:37:58 | 显示全部楼层
看看,学习下
发表于 2010-3-27 20:18:15 | 显示全部楼层
谢谢分享!!!
发表于 2010-3-27 21:29:08 | 显示全部楼层
不错不错!
发表于 2010-3-27 23:12:45 | 显示全部楼层
多谢了!!!
发表于 2010-3-28 14:09:53 | 显示全部楼层
不错的工具
发表于 2010-3-28 15:47:14 | 显示全部楼层
have a look
GMT+8, 2025-4-12 11:14
