查看: 657|回复: 2
www.merchantpromotions.com注册这家公司出问题了
发表于 2004-12-27 20:07:30 | 显示全部楼层 |阅读模式
我的帐号已经可以进去了,但是在获取广告代码时出现了错误,添加主页也不行,请看一下
Error Occurred While Processing Request
Error Diagnostic Information
You must select a media type and the site your going to put it on...
获取代码时出现的信息,给我回的第二封信原文是
The original message was received at Mon, 27 Dec 2004 04:38:13 -0500
from ntfirewall.meganameservers.com [216.251.32.227]
   ----- The following addresses had permanent fatal errors -----
<[email protected]>
    (reason: 550 5.1.1 <[email protected]>... User
unknown)
   ----- Transcript of session follows -----
... while talking to mx1.megamailservers.com.:
>>> DATA
<<< 550 5.1.1 <[email protected]>... User unknown
<<< 503 5.0.0 Need RCPT (recipient)
Attachment: Message/delivery-status
Reporting-MTA: dns; mailrelay.megawebservers.com
Received-From-MTA: DNS; ntfirewall.meganameservers.com
Arrival-Date: Mon, 27 Dec 2004 04:38:13 -0500
Final-Recipient: RFC822; [email protected]
Action: failed
Status: 5.1.1
Remote-MTA: DNS; mx1.megamailservers.com
Diagnostic-Code: SMTP; 550 5.1.1 <[email protected]>...
User unknown
Last-Attempt-Date: Mon, 27 Dec 2004 04:38:14 -0500
Return-Path: <[email protected]>
Received: from mailrelay.megawebservers.com
(ntfirewall.meganameservers.com [216.251.32.227])
        by mailrelay.megawebservers.com (8.13.1/8.13.1) with ESMTP id
iBR9cDW0008096
        for <[email protected]>; Mon, 27 Dec 2004 04:38:13
-0500
Message-Id: <[email protected]>
Content-type: text/plain
Date: Mon, 27 Dec 2004 04:37:43 -0500
Subject: Account Pending Review
To: [email protected]
还有有的公司注册里面有个payableto
这个应该填写什么,请高手指教
发表于 2004-12-27 21:16:11 | 显示全部楼层
前几天就发现了,呵
发表于 2004-12-28 01:58:32 | 显示全部楼层
我的也一样
GMT+8, 2025-4-20 12:27
