查看: 4437|回复: 20
Referer Guardian WP-BLOG插件
发表于 2010-6-14 04:15:51 | 显示全部楼层 |阅读模式
1. Block Safari/Chrome - Due to testing that you can read about here, we are offering the capability to block all Apple WebKit-based browsers. We haven't been able to personally replicate these issues with either iframes or clicks, but if you want to be extra careful, you'll want to turn this on. It will make sure that neither Chrome, Safari, or any variant are redirect to your final link. It will simply drop them at the "white hat" site.
2. Choose Post - You will find a list of post on your white hat site here. Simple select one and the list of URL's and Guarded URL's you've assigned will be displayed for you to either edit, delete, or add to.
3. URL - This field allows you to edit any current links you have assigned to a page.
4. Location - Allows you to change the allowed locations of a pre-existing link. Referer Guardian will only let users pass that come from one of the locations on this list. If you run multiple links and there are multiple location matches, the links will be randomly rotated.
5. Guarded URL - This is the URL that you will use on your black hat sites. Don't worry, the "fwd=1" part gets stripped before the user reaches their final destination.
6. Delete - Simply check the box and press the "Create/Update/Delete Links" button to delete links.
7. Post Title - This just displays the title of the post you'll be redirecting with for convenience.
8. Original Link - When you're creating new links, you'll want to put the final link you want to redirect to here.
9. Allow Location - Only users from the location you select here will be allowed to pass through to your final link. Alternatively, you can select "All" to allow users from all geographical locations through.
10. Create/Update/Delete Links - Pressing this button will apply any changes you've made, including editing, deleting, and adding new links. This will also update the global options.
这是一个WP BLOG的页面重定向插件,可以按照国家分类来定义重定向的页面,通俗的讲,就是你可以选择只有美国IP地址访问这个页面的时候,才会触发你设定好的重定向地址,我已经更新了最新的IP地址库
referer-guardian.rar
519.03 KB, 下载次数: 19
售价: 2 e币  [记录]
发表于 2010-6-14 05:44:32 | 显示全部楼层
啊啊~~几何,我的钱都被清零了。。如何是好?
发表于 2010-6-14 06:17:50 | 显示全部楼层
做个记号,用到再购买。
发表于 2010-6-14 07:34:12 | 显示全部楼层
几何的东西 确实不错
发表于 2010-6-14 07:38:58 | 显示全部楼层
这个应该是国内首发吧! 真的很不错!
发表于 2010-6-14 07:56:55 | 显示全部楼层
   做个记号,用到再购买
发表于 2010-6-14 08:11:26 | 显示全部楼层
标记 下 ,没钱
发表于 2010-6-14 08:32:00 | 显示全部楼层
几何大大的东西 就是OK
发表于 2010-6-14 09:10:48 | 显示全部楼层
感谢几何老大分享
发表于 2010-6-14 09:54:02 | 显示全部楼层
好东西。。谢谢几何
发表于 2010-6-14 10:27:19 | 显示全部楼层
大大好东西!!!
发表于 2010-6-14 15:08:01 | 显示全部楼层
这个绝对强大,好东西
发表于 2010-6-14 23:44:29 | 显示全部楼层
几何手里好东西不是一般的多呀
发表于 2010-6-15 15:38:32 | 显示全部楼层
2# laosam
不是清零,是货币改革了,以前的币不能用了
发表于 2010-6-18 01:55:08 | 显示全部楼层
好东西啊
发表于 2010-6-18 17:02:44 | 显示全部楼层
真是好东西,哈哈
发表于 2010-7-8 00:34:02 | 显示全部楼层
好东西,收藏一下
发表于 2010-7-18 18:47:05 | 显示全部楼层
到时候 用一下。。。感谢分享
发表于 2011-10-2 12:36:50 | 显示全部楼层
做个记号,感觉做CPA不错
发表于 2012-1-7 10:56:48 | 显示全部楼层
这个好东西啊
GMT+8, 2025-4-12 05:21
