查看: 1667|回复: 4
求高手帮忙翻译,小弟跪谢了
发表于 2010-6-26 15:28:34 | 显示全部楼层 |阅读模式
Create a youtube video that says; Working activation code to Adobe CS4 or some other
digital product that requires a cd key.  On the video, direct viewers to your landing page
for the code (which of course will be fake).  So disable comments and ratings, people will
be forced judge your video based on views alone (The more views the more credible).
The more popular the product is at the time you release your video, the more natural
views you will get, and the more surveys you will get filled out/more money you will
make.  Spore would’ve been a good one at the time of it’s release.
发表于 2010-6-26 16:48:21 | 显示全部楼层
这是讲YOUTUBE和你的广告结合的方法,提供了一个技巧。
试着翻译一下:
建立一个号称可以提供如Adobe CS4 等其他软件的注册码的视频。在视频中吸引你的浏览者到你的LP,去取注册码,(当然那个注册码肯定是假的)。(后面就有的难度了,楼主确认转对了吗?)所以要关闭视频的评分和回复,所以人们将被迫通过看视频,(而不是看回复),来寻求注册码,然后就是说这样会给你带来流量,从而填调查,钱,什么的。(主要思路在前都翻译了,后面的大概就是这样)
汉的骄阳 + 1
发表于 2010-6-26 18:35:56 | 显示全部楼层
应该是禁用评论和回复的功能,想得到注册码必须看完视频,利用这个做调查啊什么的
发表于 2010-6-26 20:47:56 | 显示全部楼层
貌似做CPA类的!
发表于 2010-6-27 11:08:56 | 显示全部楼层
楼主不妨把全文也放出来
GMT+8, 2036-2-7 14:31
