查看: 1537|回复: 5
WPBlog升级出现致命错误(已解决)
发表于 2010-8-15 20:48:23 | 显示全部楼层 |阅读模式
向大家请教一个问题:我今天登陆WPBlog后台,看到提示升级的消息。我点了升级后提示升级成功。然后我打开首页看到这样的提示:Fatal error: Call to a member function add_rewrite_tag() on a non-object in /home/pspbay/public_html/uhappyclub.com/wp-includes/taxonomy.php on line 289.我该怎么办呀!请大家帮助下谢谢!
发表于 2010-8-15 21:28:13 | 显示全部楼层
实在不行下载个taxonomy.php文件替换下看看。
发表于 2010-8-15 22:13:30 | 显示全部楼层
楼主用2楼版大的方法试试
 楼主| 发表于 2010-8-15 22:58:43 | 显示全部楼层
用GG找了找,发现一些高手说是由一些插件造成的。于是先关掉所有插件,然后排除法,发现是word tube 这个插件造成的,把它删除,问题解决。如何关掉所有插件步骤如下:Create an empty plugins folder
Via FTP or your host's control panel, navigate to the wp-contents folder (directory)
Via FTP or your host's control panel, rename the folder "plugins" to "plugins.hold"
Via FTP or your host's control panel, create new folder called "plugins"
Login to your WordPress administration menus
Via FTP or your host's control panel, delete the empty "plugins" you previous created
Via FTP or your host's control panel, rename "plugins.hold" back to "plugins"
发表于 2010-8-16 09:51:23 | 显示全部楼层
升级前把所有插件都停掉,必须的
发表于 2010-8-17 18:17:09 | 显示全部楼层
学习了 谢谢!!!
GMT+8, 2025-4-12 05:21
