查看: 2476|回复: 27
再发个网盘做法
发表于 2010-8-19 18:40:37 | 显示全部楼层 |阅读模式
不要看不起这些所谓的小钱,一流的项目+三流的执行力,不如三流的项目+1流的执行力。
我就见过一个马拉西亚的华人,曾经一个月做到到过K刀,最NB的是没有PORN.
How To Keep Your Hotfile Ranking in "Plantinum"?
Generally, hotfile has a complex algorithm to compute your latest rank. However, the key is based on the number of sales and downloads. Regarding the sales, we cannot control anything on this matter and we should take it as a complementary factor. The only thing we can do is to maximize the number of downloads while occupy the smallest web space. Some people say that larger files (size > 100M) have a better chance to get premium sales. I don't deny this, but what if not? I think it is just like a gamble on some uncertain things. For example, I used to upload several big files (more than 40 files, and 120M each) per day, and 60% of the downloads come from Japan. In those days, I usually got "Bronze" ranking. In the last two months, I changed the strategy by only uploading less than 10 small files (<30M) per day. However, I guaranteed that each file can be downloaded more than 150 times. Now, my rank has been sticked to 99% Platium for a long time. Although most of your files are less than 50M, you can still get a price of $7/1000 downloads, which is not bad. Currently my average price is around $8/1000 downloads.
My point is: Although large files have a great chance to promote premium sales, smaller files still do. Imagine you uploaded five wonderful small files to a forum. A user need more than one hour to download all of them because of hotfile's 15-minute-waiting-period rule. If he want all files instantly, he may buy a premium account. So, the key point is on the quality of a file instead of the size of a file. Only try to upload some files which can be download more than 100 times and your ranking will be improved quickly.
How To Build Up Your Own List Of Forum To Post Your Hotfile Links To?
Usually an elite hotfile uploader will maintain a list of forums to post their hotfile links on. Here is a trick to build your own list in a quick way.
If you go to a forum, you can find that there are usually some active uploaders who post a lot of hotfile links for downloading. If you go to another forum, you may still see the same username appearing on this forum with the same links. This is because most professional uploaders use the same username in diffierent forums to save their time. So, we can simply search this username in google, and find lots of posts posted by this user, and thus located those forums which are on the list of this professional uploader. Then we can add these forums to our own forum list and keep going. This is a quick way to build up your own forum list. You can also try some other keywords in google to find more forums. When you find a forum, you should use Alexa to see its traffic statistics, and determine if you should add it to your forum list. So you should spend more time on the expansion of your forum list other than uploading more huge files to your hotfile account.
Learn To Use Old Files
To maintain a high level of income with hotfile, you must learn to use your old files. Using the old hotfile links will save you some uploading time. Also, it will not occupy more webspace, and this file's life can be extended as well. Hotfile is happy to see users to use old hotfile links and thus your rank may have a great chance to be imporved. Since some popupar forums have a very high volumn of traffic, Your posts can not stay on the front page for a long time. So, nobody will notice that you use a link several days ago. Why not do it?
The above words are based on my actual experience. You don't have to agree with it, but please do not spread it everywhere. Good luck!
引用“woshigaozhen”兄弟的帖子。很有价值的
网盘做k很容易吧,做万刀就不容易了,自己组个服务器或者seedbox,弄个pornBlog,把排名在五千以内的Blog找到,通过远程上传,只要达到每天10万流量,你就可以一天500刀左右了,因为一般400M以上的文件,一千次是25美金左右,当然hs要低一点,不说每个文件都有人下,打对折都不止5000刀,你再自己找人开发个群发帖子软件,把所有排名前一万位的pornforum列表出来,每天只要一个内容,每天更新你Blog的一个帖子,最后注明“想看更多资源,到我Blog来吧”。流量绝对一年下来,不说月入万刀,起码K刀不是梦。当然前提是把国内ip过滤掉。本身国外网盘的国内流量不值钱,这一来把你的流量质量提高了,还有助于你不被国内和谐。因为你是做老外的生意,不对国内客户,我想安全性应该没有问题。
发表于 2010-8-19 19:32:47 | 显示全部楼层
网盘做k很容易吧,做万刀就不容易了, 自己组个服务器或者seedbox,弄个pornBlog,把排名在五千以内的Blog找到,通过远程上传,只要达到每天10万流量,你就可以一天500刀左右了,因为一般400M以上的文件,一千次是25美金左右,当然hs要低一点,不说每个文件都有人下,打对折都不止5000刀,你再自己找人开发个群发帖子软件,把所有排名前一万位的porn forum列表出来,每天只要一个内容,每天更新你Blog的一个帖子,最后注明“想看更多资源,到我Blog来吧”。流量绝对一年下来,不说月入万刀,起码K刀不是梦。当然前提是把国内ip过滤掉。本身国外网盘的国内流量不值钱,这一来把你的流量质量提高了,还有助于你不被国内和谐。因为你是做老外的生意,不对国内客户,我想安全性应该没有问题。
参与人数 1e币 +5 收起 理由
汉的骄阳 + 5
 楼主| 发表于 2010-8-19 19:36:23 | 显示全部楼层
网盘做k很容易吧,做万刀就不容易了, 自己组个服务器或者seedbox,弄个pornBlog,把排名在五千以内的Blog找到,通过远程上传,只要达到每天10万流量,你就可以一天500刀左右了,因为一般400M以上的文件,一千次是25 ...
woshigaozhen 发表于 2010-8-19 19:32
兄弟说的很不错
发表于 2010-8-19 21:00:25 | 显示全部楼层
有看过非网盘的类似做法
发表于 2010-8-19 21:01:18 | 显示全部楼层
苦力网盘过K刀很容易吗?
发表于 2010-8-19 22:09:35 | 显示全部楼层
一流的项目+三流的执行力<不流的项目+1流的执行力 支持!
发表于 2010-8-19 22:31:15 | 显示全部楼层
强大,,,这个绝对要顶起来,,太牛了
发表于 2010-8-19 22:38:21 | 显示全部楼层
不错
发表于 2010-8-19 23:45:37 | 显示全部楼层
没明白把排名在五千以内的Blog找到做什么用?
发表于 2010-8-20 02:16:13 | 显示全部楼层
很好的思路..
发表于 2010-8-20 10:16:49 | 显示全部楼层
woshigaozhen算是网盘高手了
发表于 2010-8-20 11:34:04 | 显示全部楼层
补丁一直研究网盘啊呵呵
发表于 2010-8-20 19:50:53 | 显示全部楼层
弄大了很赚钱啊
发表于 2010-8-21 15:41:52 | 显示全部楼层
弄大了很赚钱啊
发表于 2010-8-31 17:19:39 | 显示全部楼层
网盘一直都是赚一些小票
其实认真做还是可以做大票的啊
发表于 2010-9-23 02:45:53 | 显示全部楼层
很好的思路
发表于 2010-9-23 21:50:56 | 显示全部楼层
达到每天10万流量   这个价值就不止能做网盘那么单一咯
发表于 2010-9-24 07:20:25 | 显示全部楼层
学习了.........
发表于 2010-9-26 16:59:09 | 显示全部楼层
我慢慢研究,收藏了先。
发表于 2010-9-26 18:03:59 | 显示全部楼层
哈哈,不错,支持分享。
GMT+8, 2024-11-22 08:18
