查看: 1195|回复: 9
到手的刀刀快丢了AuthorityBackLinks.com 无法确认售出链接?
发表于 2010-8-31 00:34:36 | 显示全部楼层 |阅读模式
兄弟我在AuthorityBackLinks.登记的链接有人购买 可是我按AuthorityBackLinks.com 提供的链接代码在首页加上对方的链接后,却无法确认。
联系AuthorityBackLinks.com 后回复如下:
  1. Hello,
  2. Unfortunately you will need to try a different location on your page or check with your web host to see about the following error. It does not appear our bot is being served that part of the page by your web hosting server. When our bot tries to download your source code all we get is:
  3. <script>var myurl="/?";var u1="5f0f4a";var u2="87c85f";var u3="4a1433";var u4="ff0621";myurl+=u2;myurl+="=";myurl+=u4;location=myurl;</script>
  4. So it appears your web server is doing something strange to re-direct bot requests or not provide the full page code when a bot requests it. You need to check with your web hosting provider to see what the issue is. Our bot information is:
  5. Main server:
  6. Name:   svr.backlinks.com
  7. Address: 67.192.60.162
  8. Our bot:
  9. Name:   backlinks.com
  10. Address: 74.205.97.194
  11. Both of these need access to your website to download the full source code and not the above which we are getting now.
请高手给个帮助 谢谢啦!
PS: 我这站采用sdcms搭建的 用的是国外的空间!
发表于 2010-8-31 08:14:14 | 显示全部楼层
不是吧 ,这么悲剧啊!!!
发表于 2010-8-31 09:24:38 | 显示全部楼层
这个说是45天才加钱
发表于 2010-8-31 14:33:13 | 显示全部楼层
正确选择代码完整的放在网站对应的位置再看下. 以前wpBlog遇到过有插件冲突而出现错误。
发表于 2010-8-31 16:31:53 | 显示全部楼层
不知道解决了没
发表于 2010-8-31 18:13:10 | 显示全部楼层
感同身受啊  到手的刀刀就没了 餐具人寰
发表于 2010-8-31 20:40:41 | 显示全部楼层
把代码换个位置试试。
发表于 2010-9-1 21:17:30 | 显示全部楼层
杯具了,不带这样玩人的
发表于 2010-9-3 09:28:27 | 显示全部楼层
没有通过验证  你就可以卖链接了?
发表于 2010-9-3 09:34:46 | 显示全部楼层
遇到这样的是真是麻烦
GMT+8, 2025-4-16 03:50
