查看: 1272|回复: 3
24号的数据是不是显示的有问题
发表于 2010-9-25 17:20:29 | 显示全部楼层 |阅读模式
24号的数据是不是显示的有问题.只有显示,没有点击数
 楼主| 发表于 2010-9-25 20:47:13 | 显示全部楼层
Clicks reporting issue
We are aware of an issue with clicks not appearing in Performance Reporting. Rest assured, there is no loss of data and nothing needs to be done on your part. We’ll keep you posted on any updates as we resolve this issue. Thank you for your patience.
发表于 2010-9-26 10:12:08 | 显示全部楼层
帅哥你问的是什么数据?
发表于 2010-9-29 09:42:13 | 显示全部楼层
估计他太急了,是什么数据都没说就发出来了
GMT+8, 2025-4-17 03:18
