查看: 1789|回复: 4
Brad Callen关键词分析工具nichefinder下载 转
发表于 2010-12-17 13:21:06 | 显示全部楼层 |阅读模式
Brad Callen(keyword made easy,seo made easy作者) 新出的一款关键词分析工具 界面简洁 测试可用
拿以前用mnf分析过的关键词来测试  结果比较接近 也是以3种颜色来区分竞争强度
Download page:
Code:
http://nichefinder.bradcallen.com/download.php (software itself)
and
http://nichefinder.bradcallen.com/nf-customers/XULrunner.exe (needed for crack)
Crack instructions:
0. Download and install WAMP (or just set up apache if you know how).
1. Create nf-customers\verify_user.php file in your web root folder with this single line:
<license><status>ok</status><result_sn><?php echo base64_encode($_GET['sn']);?></result_sn></license>
2. Put XULrunner.exe into the same folder as above.
3. Add this line to your C:\Windows\System32\drivers\etc\hosts file:
127.0.0.1 nichefinder.bradcallen.com
发表于 2010-12-17 14:48:28 | 显示全部楼层
好像破解方法都类似 呵呵
发表于 2010-12-18 01:44:50 | 显示全部楼层
都是本地绕过网络验证
发表于 2010-12-18 10:41:43 | 显示全部楼层
过来搜落下破解版备用
发表于 2011-1-6 12:22:15 | 显示全部楼层
下来看看。
GMT+8, 2025-4-19 18:51
