Blog群管理软件,我没用,大家自己去测试
购买地址: http://www.autoblogsamurai.com/
下载地址:- http://autoblogsamurai.com/special/softwaredownxcs.php
复制代码 如何使它工作哦?
附上破解论坛的指导:(这里我简单翻译下)
To make ABS works...
1. Register with a free web hosting service. (Make sure it gives you free access to PHP) * It'll be very great if you can have a web site hosted on your very own computer so you don't need to be connected to the Internet every time you use ABS.
注册一个免费主机(确保支持php)如果你有自己的服务器更好咯
2. Create a directory named "asb" (yes, aSB!).
在你的主机空间下,创建一个目录叫“asb”
3. Open Notepad or similar plain-text editor and type "true" (without quotes), and save the file as "tranlookup.php" (include quotes).
打开记事本创建一个文件填入“true”,不要加引号,然后保存成tranlookup.php
4. Upload "tranlookup.php" to the "asb" directory.
上传tranlookup.php到asb 目录
5. Now make sure that when you go to http://your.domain/path-to-asb/tranlookup.php you see "true" printed there, and no more or less.
然后测试一下 输入 www.你的域名.com/asb/tranlookup.php 确保你能够看到“true”
6. Edit your "hosts" file (visit http://www.timeatlas.com/term_to ... with_the_hosts_file if you don't know where's this file)... add the following at the end of that file:
your-domain-or-subdomain-name www.paulponna.com
编辑你的hosts 文件(不懂建议大家去百度搜什么是host文件以及如何打开编辑),添加这样一行“www.你的域名.com www.paulponna.com”
7. Now run ABS and just type in any email address, and then press the button to validate/verify that address.
然后运行autoblogsamurai软件吧,输入任意电子邮件地址,然后点击验证
8. You should be good by now! BUT now you must edit the "hosts" file - just comment the following:
记住一定要编辑host文件!
so that it becomes:
#your-domain-or-subdomain-name www.paulponna.com
WHY??? Because that's how things work.
9.
Repeat steps #6 to #8 (i.e., edit and re-edit your "hosts" file) every time you use ABS.
Have fun!!! am
每次你启动autoblogsamurai这个软件都要编辑一次host文件,除非你买正版,祝大家愉快!
PS: On a locally hosted web site, "your-domain-or-subdomain-name" would usually be 127.0.0.1 ...
注:如果你用本机做web空间,host文件中你的 www.你的域名.com 用127.0.0.1代替就好啦
Oh by the way, you have to validate your email address every time you use ABS... and hurry up, use ABS as many times as you wish while you still can *use* it because sooner or later Paul Ponna may just turn the validation into something more complicated! bully |
