查看: 1529|回复: 10
123system35%优惠
发表于 2011-1-16 11:27:35 | 显示全部楼层 |阅读模式
In the upcoming days it will be Andrew's Birthday, For those of you who are not aware of who he is then you may read the following, Andrew is the CEO of 123Systems and has been since our company opened last year in Feburary, His birthday is in the upcoming days (8 to be exact) Jan. 24th. With this Birthday comes a birthday promotional code! This code is good for all of our virtual servers (Except the yearly plans that are already discounted), This code will function all the way up until Jan. 25th where it will then be switched off, So get it while it still works! The promotional code is for annual/biennial payment terms and applies to all vServers (Including the RAM plans).
The promotional code is: ANDREWSBDAY
发表于 2011-1-16 11:58:38 | 显示全部楼层
这是个啥米东东程序
 楼主| 发表于 2011-1-16 18:04:47 | 显示全部楼层
vps主机
发表于 2011-1-16 18:28:08 | 显示全部楼层
这个站好像没什么名气啊
 楼主| 发表于 2011-1-16 18:30:59 | 显示全部楼层
没什么名气,就是便宜
发表于 2011-1-16 20:40:37 | 显示全部楼层
额。。。这个
发表于 2011-1-17 10:20:54 | 显示全部楼层
不打算用这个。
发表于 2011-1-17 11:07:53 | 显示全部楼层
虾米站???????
发表于 2011-1-17 12:15:26 | 显示全部楼层
看来我OUT了,这站没印象
发表于 2011-1-17 14:14:02 | 显示全部楼层
VPS? 只有优惠码 没有地址
发表于 2011-1-19 10:18:20 | 显示全部楼层
全英文啊。。。。晕了
GMT+8, 2025-4-19 09:09
