查看: 1895|回复: 4
I need your help for Amazon?
发表于 2011-3-11 17:14:41 | 显示全部楼层 |阅读模式
1e币
Amazon Public Key 和Amazon API Key在哪里能找到?
发表于 2011-3-11 18:40:50 | 显示全部楼层
应该是用wp robot用吧,再仔细看下那说明就知道在什么地方找了,登陆amazon后台有个顶部很大的导航栏,点进去后需要简单的操作就可以获得。
发表于 2011-3-11 21:15:33 | 显示全部楼层
amazon public key = amazon public api key = amazon api key?
WP ROBOT COPY来的
# API Key (Access Key ID): You need a free Amazon Product Advertising API Key to use the Amazon module. You can sign up to the API for free here https://affiliate-program.amazon ... pi/detail/main.html and then find the key under "Access Identifiers".
# Secret Access Key: In addition to the API key Amazon requires a Secret Key for all calls made to the API. You can also find this key under "Access Identifiers" in your Product Advertising API account.
GG搜索来的
http://www.clickonf5.org/tutoria ... ret-access-key/6932
发表于 2011-3-14 09:32:39 | 显示全部楼层
amazon有个web service,建立一个web service的账号,然后里面有一个账户安全的选项,好像叫account security,点进去,往下拉,就可以看到了。
发表于 2011-4-6 22:47:14 | 显示全部楼层
是的在调用API那里
GMT+8, 2025-4-20 04:38
