查看: 1990|回复: 4
GG国外网赚之WordPress Plugin EarnItUp,GOOGLE网赚插件
发表于 2011-6-22 18:32:08 | 显示全部楼层 |阅读模式
WordPress Plugin EarnItUp,GOOGLE网赚插件 增加google 广告收入EarnItUp makes your ads have higher CPC value by increasing your site quality in Adsense eyes.
You can rest assured that EarnItUp makes no modifications to your website or Adsense ads as this is strictly forbidden by Adsense TOS. The EarnItUp mechanism it’s being kept only on our servers and it’s being called via a ping from your blog.
This is not an easy thing, but we managed to do it.  How we do it it’s another thing which we are not eager to share due to copycats popping all over the web, and why not, making this method not work into the future.
Why 30% ? you may ask. This is the average increase we managed to obtain. The increase can be anywhere between 20% and 40% as it depends on the niche you are into.  Just check your eCPM value as this is the easiest way to see the plugin is actually working. As you can see in the screenshot from the right, on our tests the eCPM increased with almost 30%.
下载地址:http://www.wupload.com/file/29357888/earnitup.rar
发表于 2011-6-23 09:41:12 | 显示全部楼层
blackhat?好像在WSO上面看到过这个。
发表于 2011-6-24 17:05:10 | 显示全部楼层
如果放个演示就更好了
头像被屏蔽
发表于 2011-10-14 10:15:18 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-10-17 08:51:14 | 显示全部楼层
这个插件在哪里下的,现在没有了
GMT+8, 2025-4-18 11:29
