查看: 1342|回复: 0
turn $0 into $100 with 6 proven plans in the next 48 hours
发表于 2011-8-7 23:39:45 | 显示全部楼层 |阅读模式
[Whats Affiliate Marketing?] [Whats Clickbank?] [Whats a review site?] [Whats SEO?] ->
[Affiliate marketing sounds good!, let’s try this!] ->
[This WSO looks amazing!] ->
[OK, I know what SEO is, but how do I do it?] ->
[OK, I need a website] ->
[OK, I need a template] ->
[OK, I need a sales letter] ->
[OK, I need to build a list] ->
[OK, I need this, I need that!]
Its NOT Your fault.. Blame The 'Gurus'!
Just think about about it for a moment. If there really was a blueprint, that made you thousands of dollars every night, WHY WOULD YOU WANT TO SHARE IT, WHICH WOULD MEAN SATURATING YOUR OWN METHOD!?
You already know the answer to that. The reason why its so confusing online is because these so called "Gurus" ALWAYS, leave out a fundamental pieces of the puzzle. You must buy it to make the other one work effectively. This keeps customers coming back.
The above flowchart is not even a fraction of what goes on when you first get into Internet marketing.
You probably can’t afford to hire all those services you need to get a basic website running. You might even have the technical skills but have no idea how to put all the pieces together.
Maybe they even mentioned it on their offer. That they would give you everything that you need when you purchase their product.
But then you find out you need to buy a keyword research tool, web hosting, an expensive template, sign up for something or have to buy some obscure software (like the recession didn't just happen).
I know most users here can’t afford all those services, or have the time to learn to do everything solo.
When you fall for the hype, you are a victim of "the grass is greener" syndrome. You start something, get part way through it, then see something that might be 'easier' or 'better'.
That is why I decided to create my own WSO, to help you get started with an initial investment of exactly $0.00.
That’s Right. ZERO Investment.
You do not need to purchase anything to start earning online.
I am also not going to make you sign up to a list, so I can spam you with ‘free training/PLR content/report’ offers.
I am not going to surprise you and say you need to buy additional software or services.
Wso
Code:
http://www.warriorforum.com/warrior-special-offers-forum/226552-you-warrior-sheep-turn-0-into-100-6-proven-plans-next-48-hours-hot-reviews.html
Download
Code:
http://hotfile.com/dl/52884120/3e56353/warrior.html
http://www.mediafire.com/?altyizglyyj
http://rapidshare.com/files/405263118/warrior_sheep.pdf.html
GMT+8, 2025-4-17 02:23
