查看: 1623|回复: 0
wso Supercharge Your AdSense Income by $10, $100, or even $1000
发表于 2011-8-7 23:44:50 | 显示全部楼层 |阅读模式
Supercharge Your AdSense Income by $10, $100, or even $1000 By Following my Simple AdSense Conversion System"
Dear Warrior,
Are you frustrated with your AdSense earnings? Do you spend hours upon hours perfecting your site layout in the *hope* of getting a few clicks? Do you check your AdSense stats every 2 hours but just see a big fat ZERO in the all important earnings column?
Have you spent $100s on so called "premium" themes that promise to make you an AdSense Rockstar? Have you been so disappointed with the end result that you constantly think of giving up AdSense altogether?
If you answered "yes" to any one of these questions, then my friend, this eBook is for you.
In this WSO, I'm going to tell you how you can increase your AdSense earnings within 20 minutes through purely whitehat methods. I will not only share tips and tricks that I've personally used to get 10% conversion rates across all my sites, but also give you the exact themes I use on my sites.
But don't just take my word for it, take a look at proof of my CTR:
Salespage:
Code:
[url=http://www.anonym.to/?http://www.warriorforum.com/warr ... -more-must-see.html]http://www.warriorforum.com/warrior-spec...t-see.html[/url]
Download:
Code:
[url=http://www.anonym.to/?http://www.mirrorcreator.com/fil ... n_Secrets.zip_links]http://www.mirrorcreator.com/files/CGFQE....zip_links[/url]
GMT+8, 2025-4-25 07:58
