查看: 592|回复: 0
Templatic – News Flash Theme
发表于 2011-8-12 06:36:10 | 显示全部楼层 |阅读模式
Adding Another attractive Premium WordPress Theme to the mix is the News Flash wordpress theme, as you may know already, Templatic are slowly becoming the of the leaders in wp themes on the market today, at the moment they Target mainly business but it seems they are slowly turning to other places, News flash is designed to be the perfect new theme with a brilliant layout that can cover almost any niche.
you can change the style color seven different times and get seven different choices, you don’t even need to try and resize your images because this theme will do it all for you!
Completely Search Engine Optimized, Compatible with almost ever browser, comes full with PSD, Help files and you get 24 hours support. Find out more below.
| Download Now | Preview Theme |
GMT+8, 2025-4-17 06:42
