查看: 1779|回复: 2
cj广告链接代码释疑
发表于 2011-10-2 21:36:48 | 显示全部楼层 |阅读模式
这个问题应该困扰过很多新加入cj联盟的朋友,而且在我们的广告中国论坛上也有人多次发帖咨询过,今天我就把曾经向cj客服咨询后的答复给公布在TuixyBlog上,好让更多的新手在这个问题上不再纠结。此外新接触网络赚钱的朋友也应该注意下,遇到有关联盟的问题先查看联盟上的帮助,如果还是解决不了可以直接联系客服,像cj这样的品牌联盟都会给你答复的。
Dear Tuixy,
Thank you for your inquiry. I have outlined what is necessary to track links below:
Go to the Get Links > By Relationship tab
Click on View Links next to the advertiser whose link(s) you wish to post
Click on Get HTML to the right of the text link you wish to post. You will only be able to post links for advertiser to whose program you belong.
The only portion of the code that is necessary to use in order to track your commissions, is what appears in quotations on the first line of code. The format of the reference URL is : http://www.CJtrackingdomain.com/click-PID-AID.
For example, if the code in the box appears as such: <a href="http://www.jdoqocy.com/click-xxxxxxx-xxxxxxx" target="_top" ><img src="http://www.tqlkg.com/image-xxxxxxx-xxxxxxx" width="150" height="50" alt="" border="0"></a>
The portion of the code that you need is:
We hope this answers your question. For further assistance on this issue, please don’t hesitate to log into your CJ Account Manager and click, Contact Support > Support History .
Sincerely,
Scott
Client Support Representative
Commission Junction, a division of ValueClick
看明白了吧,也就是说只有前面的那个链接对追踪佣金是有必要的,其实对于图片广告代码来说这个问题就无所谓了,但是很多人都纠结在文字链接后面也带个图片代码上。现在不用纠结了,无论是图片代码还是文字的只要用前面那个链接就可以。
Tips:和老外联系尽量一次把问题全部说清楚,以免来回邮件浪费时间;联系客服最好是在平台上的帮助那边提交问题,一般那边处理问题比较快;如果英语不好那就尽量把问题说的简单化。
参与人数 1e币 +5 收起 理由
swqlgcj + 5
发表于 2011-10-2 22:10:37 | 显示全部楼层
谢谢分享。
发表于 2011-10-3 21:27:49 | 显示全部楼层
多谢分享。
GMT+8, 2025-4-17 03:21
