查看: 1988|回复: 7
关于liquidweb上使用prosper202的一点提醒
发表于 2011-10-15 05:37:54 | 显示全部楼层 |阅读模式
原先用的狗爹的hosting,但是这段时间要大量测OFFER 怕狗爹不给力,无意间看到河马关于share hosting的推荐,果断去了liquidweb 然后安装prosper202 一切顺利,直到拿完Get Links,然后悲剧就发生了,prosper202产生的链接无法转到我offer上,显示一下结果
You don't have permission to access /tracking202/redirect/cl2.php on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.11 (Unix) mod_ssl/2.2.11 OpenSSL/0.9.8i DAV/2 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 Server at MYDOMAINNAME1.com Port 80
google以后发现是空间的问题 他们没有关闭mod_security  具体是啥我也不知道  - - ~~  最后鼓起勇气去问了support,最终是糊里糊涂别人帮我解决了问题-  -  果然如河马说的他们support 果然是hero 以下是对话内容 希望对遇见这类问题的朋友 有些帮助
Alison G.: Hello I have your account available
Long: about prosper202 problem it seems you didn't disable mod_security
Alison G.: Can you please inform me what type of error you are receiving in reference to modsecurity ?
Long: http://XXXXXXXXX/tracking202/redirect/dl.php?t202id=815&t202kw=
Alison G.: Okay disabling modsecurity entirely is not something that we suggest
Long: i'm sorry that english is not my first language~
Alison G.: We can't disable modsecurity, I just noticed that you are on a shared server
Long: yes ~
Long: you mean that i can't use prosper202 on the shared server ?
Alison G.: One moment.
Alison G.: Okay.  I have found the modsecurity list in the logs for your domain.  What I can do is whitelist this rule specifically for your domain.  Is this something you would like me to try?
Long: can you disable it ?
Alison G.: I am not going to disable modsecurity but, I will be allowing this certain location that you are having troubles with
Long: i'm sorry that i don't understand what's your mean I just want to use prosper on my shared web but it didn't work i find some information on google it seem the problem belongs to you
Long: please go to here may it is clear about my question
Long: http://prosper.tracking202.com/forum/6/21/cloaking-redirect-quits-working-after-upgrade-to-106
Alison G.: Please reload the site.  It is working now
Long: thank you very much
Alison G.: You are welcome
Long: - - how to reload ?
Long: ...
Long: OK
Alison G.: Clear your browser cache and reload the page
Long: it is working
Long: thank u again
Alison G.: I am glad to hear it is working for you
Alison G.: You are welcome.  Anything else that I can help you with today ?
Long: your are the best
Alison G.: Thank you
Long: nothing else
Long: bye
Alison G.: Good bye
liquidweb 也有AFF 但是会有信件激活 也就是给你发个信封袋激活码,所以自己refer自己 是不可能啦。 在其他空间用prosper202如果也出现此类问题 上面的可以帮助你~~
 楼主| 发表于 2011-10-15 06:46:01 | 显示全部楼层
- -  我晕啊  我哪知道你有AFF 你BLOG上也木有啊~  不过我是MONTHLY  这次到期后 我找你~~  你是刚放学吗?
 楼主| 发表于 2011-10-15 07:17:39 | 显示全部楼层
我晕  我现在是双时钟工作,我鏖战一晚上没睡  就是搞这个问题~ 这个月完了 我一定去找你~~  我睡觉啦~ 改天向你请教 :)
发表于 2011-10-15 08:35:18 | 显示全部楼层
liquidweb是用PC机当服务器的经典。
发表于 2011-10-15 10:47:00 | 显示全部楼层
这个问题好专业,只能学习了!!
发表于 2011-10-15 11:29:50 | 显示全部楼层
来学习咯!!!
发表于 2011-10-15 21:01:03 | 显示全部楼层
需要学习一下了。
发表于 2011-10-17 10:21:03 | 显示全部楼层
狗爹的hosting关键时候确实不给力
GMT+8, 2025-4-16 18:47
