查看: 2080|回复: 8
购买英文文章的模板信
发表于 2011-11-22 20:36:04 | 显示全部楼层 |阅读模式
购买英文文章怎么写需求?
方法如下: 在文章购买平台上查看别人是怎么写的需求
需求的结构大概是(情况不同,还是要根据自己的喜好而定,我大概是这个流程):
1、列出自己的关键词(每篇文章要选择3-5个关键词,可自选,如果你指定也可,但估计对方会感觉难度较大,而且文章也生硬。我是这样感觉的);
2、说明自己的原则;
3、多少字?
4、请先发给我文章的标题,自己看过后,才能开始写作。
下面是一个实例,其实这个需求很模糊,不是很给力。
"We are looking for US,England and Europe based, english speaking/writing app review writers. If you have an android or iPhone we are looking for writers that will review apps and then write a review on about the app. We will provide the apps to be reviewed. You must own an iPhone or Android device and be familiar with using apps and the app industry. These posts will be a minimum of 400+ words and should be written in a simple and understandable as well as personal style of writing. I Use This App is a mainstream Mobile App Review site and we are looking to hire some permanent positions as writers and reviewers. We will expect to see samples of writing. More details can be given during the interview process. This is a HUGE opportunity to be part of an expanding market in todays world."
我的需求基本是这样的:
i need 50 articles which 500 words each......
keywords as follows, you may pick 3-5 for each;
xxxxxx
xxxx
xxx
xx
xxx
xx
every article must be unique;
must pass copyscape;
we do not want repeating n times articles. your work must be rich rich useful info;
you should give me your thought (50 topics ) first. after i check out you may start writing.
发表于 2011-11-22 21:16:14 | 显示全部楼层
我再补充个要求模板
Your writing should concentrate on "useful infomation" not just repeat from market.
* Must have basic to advance SEO knowledge.
* Able to produce 450-500 word articles based on the keywords and topics provided.
* Must be able to do research based on the keywords provided.
* Articles must have between 1-3% Keyword Density.
* Articles must be at least 95% unique and pass Copyscape.
* Articles may NOT be spun from article robots.
* Must be fluent in English and compose excellent, grammatically correct written English.
发表于 2011-11-23 08:47:20 | 显示全部楼层
真是非常给力!!!
发表于 2011-11-23 10:39:57 | 显示全部楼层
这下规则和模板都齐了
发表于 2011-11-24 17:23:51 | 显示全部楼层
这个要收藏了,这么好的DD,哈哈
发表于 2011-11-26 23:03:14 | 显示全部楼层
果然是好东西
发表于 2012-4-3 19:57:42 | 显示全部楼层
很给力啊
发表于 2012-5-10 17:19:49 | 显示全部楼层
真是非常给力!!!
发表于 2012-5-12 23:51:04 | 显示全部楼层
谢谢了,有了参考的模板
GMT+8, 2025-4-29 01:29
