查看: 1839|回复: 4
适合做酒店型cps的Blog模板
发表于 2011-12-13 17:04:09 | 显示全部楼层 |阅读模式
具体简介:
  1. The Bel Air Real Estate v2.1
  2. The Bel Air WordPress Real Estate theme with MLS-IDX search integration is the ultimate theme for displaying your real estate listings.
  3. Built from the ground up on top of the Gorilla Themes framework, agents can login, modify and delete their own listings with a clutter free easy to understand administration. The theme can be used for a single or multiple agents platform.Compatible with all markets with currency and metrics selector and a dynamic search fields custom setup will give you the option to build your own search module, change labels and values in just one click.
  4.         Rename terms and options for the real estate search and hide-show each field individually from the search module.
  5. The theme provides optional IDX & MLS integration out of the box with dsIDXpress subscription to display your listings and build your IDX MLS search widgets.
  6. Live MLS data directly on your own website and on your own domain with search engine friendly urls.
  7. dsIDXpress plugin outpout search engine optimized pages indexable in your site with great SEO optimization.
演示站点:
  1. http://gorillathemes.com/demo/thebelair/
下载地址:
  1. http://www.restfile.com/8y539ml6yack/wp.rar.html
发表于 2011-12-13 19:46:38 | 显示全部楼层
这个不错,必须支持一下。
发表于 2011-12-14 13:40:33 | 显示全部楼层
支持一下
发表于 2011-12-14 16:18:14 | 显示全部楼层
好东西,多谢分享了
发表于 2011-12-15 10:05:18 | 显示全部楼层
手上有几个酒店广告,可以试一下
GMT+8, 2025-4-14 15:22
