查看: 2348|回复: 14
CJ做正规销售为什么收到调查信?
发表于 2012-1-31 07:58:59 | 显示全部楼层 |阅读模式
CJ帐号申请很长时间了,以前没怎么做,1年加起来也就几百刀,1月份选了两个产品重点做了一下,这个月佣金2000多刀,是100%自然流量的正规销售,郁闷的是,今天收到CJ的调查信了:
After performing an extensive review of your performance in the Commission Junction network as a Publisher, Commission Junction is providing you the following warning:
Please provide a detailed explanation as to how you are driving traffic to advertisers in the network and how does traffic reach your site
Commission Junction will exercise its right to terminate your relationships through the Commission Junction Publisher Service Agreement, within 15 days of this notice if you do not take the necessary and appropriate correction actions. Failure to respond shall be deemed an admission of liability and acceptance of this letter as 15 days notice of termination, and may result in Commission Junction exercising its right to terminate the Commission Junction Publisher Service Agreement 15 days from the date of this written notice or sooner.
In the event of deactivation you will be required to remove all links/ banners by that deactivation date because you will no longer be authorized to post such links/banners and will not be receiving any compensation for referrals through such links/banners. Additionally, during this interim 15-day period from the date of this notice, if violations of the Commission Junction Publisher Service Agreement are identified, your account may be terminated in Commission Junction’s sole discretion, transaction may be reversed from your account ("charged-back"), and any attempt to rejoin the Commission Junction Network shall be null and void.
CJ应该有途径知道我的流量来源吧,为什么会发这样的调查信?我该怎么回复呢?
发表于 2012-1-31 08:30:01 | 显示全部楼层
合理的解释一下就好,提供点证据
发表于 2012-1-31 09:41:40 | 显示全部楼层
收到调查信 不是一定K号..
 楼主| 发表于 2012-1-31 09:58:20 | 显示全部楼层
 楼主| 发表于 2012-1-31 10:00:10 | 显示全部楼层
是不是短期内EPC太高的原因?
发表于 2012-1-31 13:01:59 | 显示全部楼层
遇到调查如你所说是正规sale那就提供些证据过去,说清楚后没有问题的。只有被广告商投诉那确实很难解决,来自cj的常规调查说清楚点容易解决的。
一,提供流量是如何达到你网站的解释;
二,提供你是如何把流量从你网站引导到广告商那的解释;
你这个应该是短期内epc太高引起来的。
 楼主| 发表于 2012-1-31 13:35:03 | 显示全部楼层
遇到调查如你所说是正规sale那就提供些证据过去,说清楚后没有问题的。只有被广告商投诉那确实很难解决,来 ...
dxszzcylm 发表于 2012-1-31 13:01
感谢老大的回复,已经给CJ回信并提供截图证明了,看看啥时能解决
发表于 2012-1-31 14:21:47 | 显示全部楼层
EMU都说得过去何况你是正规sale,不要被调查信吓到
 楼主| 发表于 2012-1-31 14:32:49 | 显示全部楼层
罗曼蒂克 发表于 2012-1-31 14:21
呵呵,有道理
 楼主| 发表于 2012-1-31 17:26:51 | 显示全部楼层
怎样知道CJ是否审查通过了呢?通过之后有邮件提示吗?
发表于 2012-1-31 23:22:38 | 显示全部楼层
赚个钱真不容易啊
发表于 2012-2-1 00:03:19 | 显示全部楼层
在其它坛里年看到都有这样情况,正常莫怕。
发表于 2012-2-4 15:01:30 | 显示全部楼层
其实收调查信未必是坏事
 楼主| 发表于 2012-2-4 15:42:25 | 显示全部楼层
其实收调查信未必是坏事
hlzone 发表于 2012-2-4 15:01
呵呵,难道是好事?
发表于 2012-2-4 16:03:56 | 显示全部楼层
还真说不定是好事
GMT+8, 2025-4-12 11:17
