查看: 2415|回复: 22
dreamhost挂了
发表于 2012-4-23 16:58:37 | 显示全部楼层 |阅读模式
Current Outage: Hardware replacement on your shared web hosting server kigali (updated 4 hours 55 mins ago)
Hello,
We wanted to update you on the status of the ongoing restore for your shared web hosting server "kigali".
Due to issues with the RAID controller, we have replaced the hardware for this server and we are restoring all data from our backup server to the new hardware. During this process, the data on the backup server will be mounted directly over NFS to allow your hosting services to remain online for the duration of the process. The restore is running without any issues and all sites are reporting up.
There may be periods of high load on the server due to this restoration, which is caused by the large amount of data being sent to the server. We will be closely monitoring the server and mitigating that load wherever possible. The restore is progressing well, and a bit over half of the users are completed at this time.
We apologize for the inconvenience caused by this unplanned maintenance. If you have any questions or concerns, please contact Support under Support -- Contact Support, in your Web Panel. This notice will also appear on that page in your Web Panel and will be updated throughout the process with the latest details we can provide.
Thank you for your patience!
The Happy DreamHost Server Fixing Team
快5个小时了。空间里的所有文件都穿越到了09年和11年。流量大受影响,收入更是惨不忍睹。
求坛子里的英文站老手推荐个稳定点的空间。dh经常抽风,bh一直在使用,稳定性不错,只是只有一个ip。
发表于 2012-4-23 17:06:55 | 显示全部楼层
俺用GD
发表于 2012-4-23 17:30:48 | 显示全部楼层
做站群的话 不大清楚
但是如果做网站的话 用gd就可以了.
 楼主| 发表于 2012-4-23 17:35:18 | 显示全部楼层
gd的国外访问如何?我的是下载站,日2000-3000IP。
发表于 2012-4-23 17:53:42 | 显示全部楼层
HG还可以啊,但是也只有一个IP。多IP的好像只有DH了。
发表于 2012-4-23 17:56:33 | 显示全部楼层
dh的抽还是很少的。
发表于 2012-4-23 17:57:53 | 显示全部楼层
 楼主| 发表于 2012-4-23 18:33:56 | 显示全部楼层
回复 6# dxszzcylm
    dh抽的不要太频繁哦,都称月经了。bh倒很少抽。
 楼主| 发表于 2012-4-23 18:35:32 | 显示全部楼层
回复 7# cjyzpcl
    相对dh和bh来说,好贵哦
发表于 2012-4-23 18:49:37 | 显示全部楼层
便宜没好货
发表于 2012-4-23 19:15:26 | 显示全部楼层
回复  cjyzpcl
    相对dh和bh来说,好贵哦
xizi1023 发表于 2012-4-23 18:35
    2000ip一天还觉得19.99刀贵,我觉得你也可以了
 楼主| 发表于 2012-4-23 19:17:16 | 显示全部楼层
回复 11# cjyzpcl
    舍不得嘛。。。
发表于 2012-4-23 20:57:38 | 显示全部楼层
回复  cjyzpcl
     舍不得嘛。。。
xizi1023 发表于 2012-4-23 19:17
小七,速度联系我....
发表于 2012-4-23 21:22:29 | 显示全部楼层
好像已经恢复了
发表于 2012-4-24 00:17:37 | 显示全部楼层
推荐hostgator
发表于 2012-4-24 10:58:20 | 显示全部楼层
DH经常出点小问题
发表于 2012-4-24 13:14:50 | 显示全部楼层
用VPS不就解决了?真是。。。
发表于 2012-4-24 14:24:42 | 显示全部楼层
也用的DH,去年年末那段时间深受其害,但是今年到现在为止还没有发现过问题,也许跟我最近很少登陆后台有关吧。不过去年有段时间挂的厉害,跟DH说了之后还给了我一个续费折扣,感觉DH服务还是可以的。
发表于 2012-4-27 09:39:31 | 显示全部楼层
HG小鳄鱼吧,稳定,无月经不调
发表于 2012-4-27 20:01:50 | 显示全部楼层
DH还凑合,对我来说
GMT+8, 2025-4-23 03:24
