查看: 1130|回复: 6
Making money on Twitter without the use of CPA
发表于 2012-5-21 23:51:09 | 显示全部楼层 |阅读模式
Let me be honest every day I
hustle the hell out of twitter to make money with email submit leads.
The money is alright I sit everything up so it is almost like autopilot
money for me. Everyday I make money. Everyday I make someone else even
more money. Now to me it seems like hustling twitter for some email
leads for someone else when that money can be going into my pocket seems
counterproductive. I guess at times I am deeply against CPA why make
someone else money when you can make that money for yourself? So I had
me a long think tank session on what kind of leads or money can I
generate for myself using twitter.
As I have said in my last tutorial the value of a lead is 1.00 a month
per lead to you. So during the life of that lead it will or should
average you about 1.00 a month. So if you are getting 50 leads a day via
twitter for yourself that is 50.00 a month every month. You get the
picture. So basically you can hit twitter hard for a few months then
essentially just chill out for a few months until your leads start dying
off. You can also laser target your leads as well and as I am going to
show you EXACTLY what I did even steal your competitions customers.
Now I must warn you to find your own niche as for the exact thing I describe and my results are from hitting twitter hardcore.
So I got to thinking what do I have what do I know about that these
people would want? The internet marketing niche is full of bots so it
would be since-less to go after that. Then I had a stroke of genius.
HOSTING! I have a enough space left open I can offer some really cheap
discounted hosting. Like starter plans for only 1.50 with the coupon.
Now I do not care who you host with but for a host that is a good price.
Now 1.50 cents is about what I get for a email submit lead. So the
price will equal up to about the same. Though the beauty of it is my
income will actually compound every month. As my hosting is a
subscription basis.
So here is exactly what I did. I spent the better part of 2 days working
on my site and getting up a commercial biller. As the biller I had was
one designed and coded by myself using open source scripts. Next I
worked on the site itself it looked like it was a design from the 70's
no joke it was horry bad. It still is bad and I am most certain that it
is why it did not convert even better. *Just ask Grif let him check it
over he will tell you the site is horry bad.*
Next I created coupon codes for some of the top host like hostgator and
Nonads I mean godaddy. I set the normal price to 3.00 and the coupon to
lifetime 50 percent off for only 1.50 a month. So I am sure that 1.50
catches some peoples eye balls.
Next I created custom messages for each host. This was probably the
longest part. As I had to have the coupon code in the message as well
and it could only be a certain length. This actually led me to
shortening the coupon codes actually. Like for example HG50 instead of
what I had which was hostgator 50.
Next I scraped my victim following list. BTW check out hostgator on
twitter lot of tech support going on there which shows they are a very
bad host.... Why does ANYONE every host with them? So I scraped anyone
following hostgator for starters. Now this is a good things that a lot
of people there support from there. That means a lot of fed up pissed
off angry people who just want answers and could not get it resolved via
normal means. Yea for me. So I scraped them.
Next I blasted that list it took me about 12 hours to blast the whole
list with a message.. After that I took a short break. I came back and
hit them again for another 12 hours. To get the people I might have
missed or for some reason twitter removed the message before they saw
it.
Next I repeated that exact same step only I did it with godaddy. So this
is what I have been doing and have done it for about 3 days now with
different host. So I know it sounds like a lot of work to do but
honestly it is not that bad. As most of the work is handled by a bot.
What are my results so far?
Like I said my website is horry bad. I actually was not even sure this
was going to work to be honest. YET it DID work. Maybe if i made some
tweaks here and there it will work better no doubt. Though I think for
just coming up with an idea and trying to implement it as fast as
possible I would rate this a perfect that can get better. As of to date
this has earned me a grand total of 30.00. i know it is not that much
but like I said it is recurring and it is money in my pocket and not
some CPA fat cat getting rich off of my work.
You try the hosting niche chances are you will fail doing exactly what I
did took a whole hella lot of spamming twitter. Though it was not fail
and I could do this day after day and in 10 months yeah some decent
amount of cashflow there. For me that is too long of a wait for some
real cash from hosting. I know i know i can do other stuff to get
hosting clients but this was only an experiment.
You CAN use this for other niches. Take email leads for parents. Create
an ebook for parents give it away if they sign up to your list or
whatever other niche you want the opportunity is endless here and you
can make so so so so so much more money then just spamming email submits
if you just put your brain on it and make money for yourself and not
someone else.
 楼主| 发表于 2012-5-21 23:51:20 | 显示全部楼层
Why not just prepop the leads?
Get em on your list and get em to do an email submit as well.
 楼主| 发表于 2012-5-21 23:51:31 | 显示全部楼层
Not on topic there Klix.... This is about not using CPA . I do however have some twitter CPA tricks that will blow your mind.
 楼主| 发表于 2012-5-21 23:51:41 | 显示全部楼层
Well it was more directed to your last paragraph about giving away free ebooks... Better to squeeze that extra $2 out of them then give them an ebook right away.
I guess that would decrease the amount of conversions though if you go offer a free iPad to a parent looking to fix their kid.
 楼主| 发表于 2012-5-21 23:51:50 | 显示全部楼层
Oh yeah you are right. You can use anything but it is best to treat your list like family as it is your bread and butter. Never throw the proverbial shit on the wall at em. Always send an email that will help to fix there problems. Like you said a free ipad to a stay at home mom trying to fix there kid might not be a good idea. BUT needless to say not saying that a CPA for parenting magazine will not. however just throwing them at that offer will not garner you any love. Tell them WHY you are recommending that magazine. Many many many different routes to go with this but the thing is you have to remember with when dealing with the list is answer there why before it is even asked. Main WHY to answer is why are you showing me this offer.... Though that is all for another day
发表于 2013-8-20 18:46:15 | 显示全部楼层
额,杂么全是英文啊
发表于 2013-8-21 20:00:44 | 显示全部楼层
额,提炼两句哈
GMT+8, 2025-4-25 13:53
