查看: 1358|回复: 2
dreamhost 域名绑定
发表于 2012-9-14 17:19:31 | 显示全部楼层 |阅读模式
发现从淘宝买的一个dr空间打不开了,自己买了dr的空间,想把以前在淘宝买的dr的空间绑定的域名绑定到我的dr空间,结果不行。
what happen is that a friend of mine used to host this domain for me in his dreamhost account because I didn't have a hosting, now I got a dreamhost account too and I'm trying to host it but doesn't allow me.
domains are:
aaa.com
bb.com
以下是回复:
Hello,
My apologies for the trouble!
I would be happy to assist you with this.
Checking into your issue there are 2 problems. Which both need to be
corrected before you can host those domains.
1. The domains you had listed are still listed on your friend's account.
They would have to be removed from that account, before you can host
them on another account. Now, the domains cannot be removed from your
friend's account, as the account is currently suspended.
2. You have used a promo code when you signed up. This prevents you
from hosting any previously hosted domains on the promo account. The
promo code would have to be removed and the discounted rate paid in full,
before you can host any previously hosted domains.
If you would like the promo code removed, please reply back to me with
your confirmation.
I hope that helps!
Thanks!
Jay H
所以,给大家些经验吧。
发表于 2012-11-11 02:15:41 | 显示全部楼层
淘宝买的空间是用promo code买的,如果到期不续费,那么所有绑定的域名都不可以绑定在新的空间上
 楼主| 发表于 2012-11-11 08:12:20 | 显示全部楼层
呵呵,自己向dr买了,以后肯定不会在淘宝买了。也提醒童鞋们不要在淘宝买。
GMT+8, 2025-4-25 12:47
